Guys,
Last May, my wife and I purchased a 2004 Cadillac DeVille DHS. Since the weather was warm we had the opportunity to check out the air conditioning system, but not the heating system. I read through the owner's manual to check out all of the controls and the manual seemed to indicate that when in AUTO mode, the user doesn't need to do anything to get heat...the system takes care of the whole operation. Last night I took the car out when the temperature was 23 degrees, so obviously heat was needed. I set the inside temperature to 74 degrees and left the system alone in AUTO Mode to see what would happen. What happened, basically, was nothing. After about 15 minutes, the fan never turned on, so the car never warmed up. Finally, I turned on the fan manually and then I got heat. The manual seems to indicate that the system should turn on the fan automatically and control the fan speed automatically.Either the system is broken and I need to get it fixed, or I don't know what I'm doing and am too dense to understand the manual. (Either is possible!).
Can someone who has a working heating system tell me how your system operates so I can see whether or not I need to take advantage of that expensive warranty that I bought? Thanks in advance...!!!
Bob
Bob
