I have a 2003 Cadillac Escalade ESV Vin # 3gyfk66n03g330192. I have had the parasitic draw for years, but know i am TIRED of it!
I want a permanent solution! I have tried to have my local dealers to flash the BCM again, but they want to charge an multiple hours labor! They don't believe this is the problem because the vin doesn't fall in between the original bulletin range. If i ever disconnect the battery i will be throwing my money down the drain..\
Anyone know of a permanent solution?
The original Bulletin:
#02066 -- Battery Drain
involved vehicles are certain:
2003 Chevrolet Silverado, Tahoe, Suburban; 2003 GMC Sierra, Yukon, Yukon XL; 2003 Cadillac Escalade, Escalade EXT, Escalade ESV
Equipped with Quadrasteer (NYS), Autoride (Z55), or Vehicle Stability Enhancement/StabiliTrak (JL4)
December, 2002
Dear General Motors Customer:
We want your experience owning your 2003 model year Chevrolet Silverado, Tahoe, and Suburban; 2003 model year GMC Sierra, Yukon, and Yukon XL; and 2003 model year Cadillac Escalade, Escalade EXT, and Escalade ESV vehicles equipped with Quadrasteer, Autoride, or Vehicle Stability Enhancement/StabiliTrack to be better than any other you've had ... which is why we're writing.
We have learned that your 2003 model year Chevrolet Silverado, Tahoe, and Suburban; 2003 model year GMC Sierra, Yukon, and Yukon XL; and 2003 model year Cadillac Escalade, Escalade EXT, and Escalade ESV vehicle may have the potential of exhibiting a battery drain condition. An anomaly in the operation of the steering wheel position sensor may keep the Body Control Module (BCM) from shutting down when the key is in the OFF position. The resultant 3.5 amp draw/load on the battery could possible discharge the battery to the point where the battery will not have sufficient amperage to start the vehicle.
What We Have Done
We've sent a new BCM calibration to your dealer so that your vehicle can be reprogrammed to ensure that the BCM shuts down when you turn the vehicle off. This service will be performed for you at no charge.
What You Should Do
We recommend that you contact your dealer to arrange a service date. If you have experienced this condition in the past and your battery was recharged or replaced, your vehicle will still need to be reprogrammed.
here are the VIN breakpoints to determine if your vehicle is possibly involved (contact your dealer or the customer assistance certain to determine for sure):
Plant: Flint
Through: 3F165707
Plant: Oshawa
Through: 31235800
2003 Chevrolet Tahoe
Plant: Arlington
Through: 3R181251
Plant: Janesville
Through: 3J179899
2003 Chevrolet Suburban
Plant: Arlington
Thtough: 3R181251
Plant: Janesville
Through: 3J183738
Plant: Silao
Through: 3G183738
2003 GMC Sierra
Plant: Flint
Through: 3F165315
Plant: Oshawa
Through: 31235792
2003 GMC Yukon
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
2003 GMC Yukon XL
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
Plant: Silao
Through: 3G183779
Plant: Arlington
Through: 3R181357
2003 Cadillac Escalade EXT
Plant: Arlington
Through: 3G183821
Plant: Arlington
Through: 3G183821
December, 2002
What We Have Done
What You Should Do
Plant: Flint
Through: 3F165707
Plant: Oshawa
Through: 31235800
Plant: Arlington
Through: 3R181251
Plant: Janesville
Through: 3J179899
Plant: Arlington
Thtough: 3R181251
Plant: Janesville
Through: 3J183738
Plant: Silao
Through: 3G183738
2003 GMC Sierra
Plant: Flint
Through: 3F165315
Plant: Oshawa
Through: 31235792
2003 GMC Yukon
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
2003 GMC Yukon XL
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
Plant: Silao
Through: 3G183779
Plant: Arlington
Through: 3R181357
Plant: Arlington
Through: 3G183821
Plant: Arlington
Through: 3G183821
