1991 seville
89 deville. Nice and high on the right, lower on the drivers side. Is there an adjustment that can be made to the drivers side??
Air is shared between both shocks. If one side is higher than the other, there's another problem. Sagging/broken spring, damaged suspension component...
1985 Fleetwood 75
Sounds like the high shock has stuck in the extended position and binding. both shocks in the stationary position with no weight to activate leveling should be same height. There should be a static air pressure held in the shocks this is to protect the
seal. about 4 to 6 psi residual. it is held by the pressure check valve behind the compressor. if remove an airline from shock when stationary there should be some air come out. could also be a plugged line that is not venting properly.
Also see if spring has a broken coil at end of spring could have rusted and broke lost tension and sagging.
replace both rear leveler shocks at same time.
