Is There A Sensor for "Fuel Used"?
3164 Views 42 Replies 15 Participants Last post by  ronr
The "Fuel Used" gauge on my Info is way off, i.e. it shows 10 gallons used when it takes 14. I've checked it several times and it's way off. Before I bring it to the dealer, I'd like to know what the fix might be so I don't have to have them make me come back a second time.
1 - 20 of 43 Posts
hmm wierd...I know the fuel used is the only accurate thing on my car...the in-dash gauge is useless, so is the remaining miles....but, I don't think there is a specific sensor for it...I know there is a TSB out on inaccurate fuel readings...being an 04' I wonder if your car is experiencing that, and if the fuel used could also be attributed to that.
I looked at the list of TSBs on FAQs and couldn't find any reference to this. Do you have a date, # or other info that could help me pin this down?
Thanks!
I'm assuming you push the reset button after fillup, and it still reads off?
Not at all. It reverts to 0, as it always has. But when I fill up again, it's off by as much as 40%.
I have to manually reset my fuel used info after I fill the car up ?
My fuel used is fairly accurate, usually off by only about 1/2 gallon.
ya, I have to reset mine manually as well.....when's the last time you took a trip to the eye doctor :p j/k I'd say somethings screwy with the computer, because I've never had mine reset itself like that.
I believe that the computer merely calculates the fuel used by dividing the miles by the average fuel economy, since the last reset. If your trip odometers are accurate, and your average fuel economy is accurate, then your "fuel used" should be accurate.
Mine are all accurate.
Not to hijack the thread, but my cals are all messed up too. At 1/2 tank on the analog guage I have a DTE of 120 miles and my fuel used is 10.2 gal. However, my trip counter was already at 170 miles. I haven't had the car long, but I've filled up 3 times and all three times I've made it about 210 miles per tank.
Why do I get 170 for the first 1/2 tank and 40 miles for the second? I'll keep an eye on the gallons used as it get's near E.
The fuel burn indicator is adjustable in the PCM. It would be very strange if the value was changed from the factory default.
The key word here is "approximate".
The information on fuel usage is all calculated based on when you reset it and the approximate fuel level in the tank based on the readings from both sensors.
There are two fuel level sensors in the CTS and CTS-V fuel tank. The computer watches them both and uses data tables to calculate the fuel quantity based on the voltages from the sensors.
Software controls the reading since values can fluctuate during driving due to fuel slosh and without a "buffer" the values will fluctuate wildly.
You must reset the values anytime you are doing real mileage monitoring.
It does not reset by itself when you fuel up.
(as far as I know anyway)
No, it does not reset by itself. I'm talking about when I reset it. That's when it's off by as much as 40%.
I suspect there could be room for some error in the way the fuel amount is calculated and I know that there is a portion of the tank that is not measurable once it reaches a certain level. From there it is up to the PCM programmer to decide how the ECM is measuring how much fuel you have.
There are no bulletins regarding a concern like this.
Perhaps you should verify a department of agriculture weights and measures certification on the pumps you use to fill your car.
Have you ever run out of gas with the gage still showing that you have some? That is the only problem I have seen with any CTS fuel system, except a few rare outright pump failures.
would the fuel transfer pipe TSB apply here? Perhaps if the tanks are not equalizing properly, this could throw off the guage and thus the calculation..
Is your fuel guage accurate?
Reed
If one of the sensors is bad the computer should be able to detect it, when that happens it usually sends the fuel gage to empty and puts on the low fuel light (depending on the failure).
They are pretty good about not lying to the ECM by giving wrong data due to the way they are designed and the way the computer monitors them for faults.
Typically the fuel transfer problem causes you to run out of fuel with 1/4 tank showing on the gage.
I think this also has something to do with track usage. Back in 2004, I ran out of gas on the track twice when it showed more than 1/4 tank. In both cases, I was able to restart the car after sitting for a couple of minutes.
After that, I started using the "Fuel Used" guage whenever I was at the track. So as soon as it showed 10 gallons or so, I would refuel. But last week at Pocono, I noticed when it showed 10 gallons used, it was taking 14 gallons to fill it. The Fuel Used was off every time, by as much as 40%. I filled it myself each time right to the spout.
That's why I made the original post.
Well it sounds like you might have an issue with the fuel transfer.
You need to make sure your dealer knows you have been running out of gas with 1/4 tank on the gage, if you tell them you are having problems with the fuel used display they might not do much.
If you tell them you are running out of gas, they will probably fix it.
Whew! I dipped under 1/4 tank at VIR and had no problems. I think trukk and MWD did the same, we all had to refuel at the same time. Our Vs were thirsty. They don't have '04s but I do.
*Note to the memory banks...
Hello, did I miss something? Was this an event or did you just head over by yourself? Damn, I need to monitor this board more!
1 - 20 of 43 Posts
