ive been trying to find out to put a kenwood dnx 5120 in my car i hope it fits thx for any info!:hide:
Yes it does, it also works after you shut the car off till you open the door or 10min and also dims when you turn on the lites, works exactly like the boes i removed..dave does your double din work then you pull the key back in acc
how the hell did u get that to work? im stuck with mineYes it does, it also works after you shut the car off till you open the door or 10min and also dims when you turn on the lites, works exactly like the boes i removed..
Regular radios are single din and the big one pictured in twice as big ,hence the double din..you can put either in your car but double din will look better..Is a size standard for car stereos, single DIN and double DIN. Double DIN is twice the size of a single DIN but are slightly shallower. There is also a 1.5 DIN. The size of a DIN is 7” width by 2” height (4" x 7" for double DIN).
This is what you will call single DIN
And this is what you will call double DIN![]()
Our cars are Double DIN![]()
double din looks more factory than a single din imoWhat the hell is double din?
On your factory plug use a test lite to find the wire thats hot with key on and in acc that will connect to the yellow wire on aftermarket radio and the one thas hot all the time (on the factory plug ) will be red on the aftermarket radio,,how the hell did u get that to work? im stuck with mine
really yellow is acc oh i had the yellow and orange together with the power wire to the player. so i hook the yellow to th red acc wire on the harness and leave just the orange to the red ?On your factory plug use a test lite to find the wire thats hot with key on and in acc that will connect to the yellow wire on aftermarket radio and the one thas hot all the time (on the factory plug ) will be red on the aftermarket radio,,
Damn !! in knew i get it backwards ..the yellow in constant + and red is switched + and if you put power to the orang it will dim the screen..Sorry for the mix up i knew i should hav looked first..:lies:really yellow is acc oh i had the yellow and orange together with the power wire to the player. so i hook the yellow to th red acc wire on the harness and leave just the orange to the red ?
This mostly help the aftermarket stereos industry…frankly I have no idea why me as a car manufacturer will adhere to a standard that does nothing for me, just helps somebody else to sell his products. Must be some reason in miss...I thought it was some technological term. You mean it is a dimension and they are standardized? Why?
Hey what kind of adapter do i need?yeah ^ since you have bose your going to need an extra adapter
