Guys,
In a previous thread, we established that the traction control system will "simulate" an LSD in low traction situations and several of us posted pictures of nice parallel tire tracks on burn-outs. If one wheel was spinning entering a tight turn, all the power would go to the spinning wheel (which is usually the inside wheel) and the car would actually abruptly loose acceleration. I know because the clutch packs in my Camaro's LSD failed at ~240,000 miles and it started acting like an open diff. The car became almost undrivable in slick conditions because I seemed to be lighting up one wheel all the time at exactly the wrong moment. I was so happy to replace the dead unit.
I've had a lot of fun/experience hanging the rear end out on slick days in the Camaro (when the LSD was working properly) and the ATS does a decent job simulating the same dynamics... to a point. If you goose it too much, traction control will kick in and cut power to stop your drift. Turning Traction-Control off while in sport mode will allow you to do donuts in a snowy parking lot or drift a bit around a slick corner (things you absolutely could not do in a traditional open-diff car). It's actually a lot of fun to toss around if you are used to these types of driving dynamics.
A good all-season performance tire would increase overall grip while maintaining a sporty feel. Unfortunately, the selection of good all-season speed-rated run-flat tires is pretty small. They do exist, but I'm considering going to conventional tires once my current set wears out. I'm not sure if I will actually go that way, but I'm really considering it.
Random side-note: I've noticed that the combination of traction control and Stabili-Track in sport mode will actually work together to "fool you" into thinking the stock tires are better than they are. What I mean by this is the car will make lots of minute "adjustments" when driven hard to keep the tires within their limits. There is a corner on my daily commute that I can hit 'quite aggressively." My Camaro has better tires and sticks this corner like a howling madman, but I usually end up taking it slower than the ATS because the Camaro's chassis feels much more twitchy. By contrast, the ATS in sport mode with traction control & Stabili-Track enabled feels like it is KILLING" this corner because it's actually holding me back and will not LET me over-drive the car, but in a good way. I can feel it intervening, but it still feels planted and confidence inspiring. With the electronic assists turned off, the ATS's chassis still feels great, but I'm free to blow past the tires' limits and I have found myself balancing on the edge of understeer and a four-wheel drift more than once because the tires just couldn't keep up with what I was asking them to do.
Sorry for the long post. I hope this info is helpful.
