searching at gmpartsdirect.com i was looking for a sway bar link kit for my mechanic told me that whats making a clunking sound when i go over bumps. I found a stabalizer bar link kit is that the same thing?
Caddlovers is correct. They make a different sound...a squeak. The bump sound I found on my 97 was the strut bushings worn. The way to tell if you have this is to raise the hood and check the strut upper support plates. If there is a gap between the circular plate and the strut tower you will hear a thump when you hit a bump. Use a jack to raise car high enough to get wheel off the ground and the gap goes away as the suspension drops. You car does the same thing when you hit a bump.gritter said:searching at gmpartsdirect.com i was looking for a sway bar link kit for my mechanic told me that whats making a clunking sound when i go over bumps. I found a stabalizer bar link kit is that the same thing?
97cateraowner, i sent you a pm, cuz you described exactly the noise when going over bumbs. I've gone on rockauto.com and cant seem to find "strut bushings." you help would be greatly apprecaited. :alchi:97cateraowner said:Caddlovers is correct. They make a different sound...a squeak. The bump sound I found on my 97 was the strut bushings worn. The way to tell if you have this is to raise the hood and check the strut upper support plates. If there is a gap between the circular plate and the strut tower you will hear a thump when you hit a bump. Use a jack to raise car high enough to get wheel off the ground and the gap goes away as the suspension drops. You car does the same thing when you hit a bump.
found a stabalizer bar bushing but no strut bar bushings. Got a link to a place to find the strut bushings?97cateraowner said:Caddlovers is correct. They make a different sound...a squeak. The bump sound I found on my 97 was the strut bushings worn. The way to tell if you have this is to raise the hood and check the strut upper support plates. If there is a gap between the circular plate and the strut tower you will hear a thump when you hit a bump. Use a jack to raise car high enough to get wheel off the ground and the gap goes away as the suspension drops. You car does the same thing when you hit a bump.
Deff is a gap, and i raised the driver side tire up and the gap closed on the driver side. So i'd guess this is the problem! Now the next problem is where do i find these suckers lol97cateraowner said:Caddlovers is correct. They make a different sound...a squeak. The bump sound I found on my 97 was the strut bushings worn. The way to tell if you have this is to raise the hood and check the strut upper support plates. If there is a gap between the circular plate and the strut tower you will hear a thump when you hit a bump. Use a jack to raise car high enough to get wheel off the ground and the gap goes away as the suspension drops. You car does the same thing when you hit a bump.
could the strut bushing also be the part listed undergmparts direct as the strut mount bearing part # 9050005797cateraowner said:Caddlovers is correct. They make a different sound...a squeak. The bump sound I found on my 97 was the strut bushings worn. The way to tell if you have this is to raise the hood and check the strut upper support plates. If there is a gap between the circular plate and the strut tower you will hear a thump when you hit a bump. Use a jack to raise car high enough to get wheel off the ground and the gap goes away as the suspension drops. You car does the same thing when you hit a bump.
For some reason my browser could not view the image. I added item to my cart so I could see part number and it is hard to believe GM would sell the entire thing for that price, So my guess it is just the bearing. I would call their customer service.gritter said:could the strut bushing also be the part listed undergmparts direct as the strut mount bearing part # 90500057
