Re: Ipod Kit Hooked Up
OK,
So I hooked up the kit using the directions found at cadillacfaq.com. It works but there is some confusion in the directions about wiring it into the XM reciever. I took the first cut the red/white wire and wired the red wire into the kit but of course only the IPOD worked so I also wired the other end of the red/white xm wire that I cut in and now both xm and IPOD work. BUT,,,
the readout on the screen is inconsistant. When using the IPOD the soft keys on the right side of the screen show XM preselects and when I hold the bottom key down to change to XM, the name changes to whatever is playing on the IPOD IE: D0 T1 That part I can live with but sometimes when playing the IPOD the screen shows the program from the XM channel I've got a call into radiosandmore so will see what they say when they call back.
Sounds good
