iPhone Integration
10228 Views 52 Replies 17 Participants Last post by  MVP
I just started a new job which has me in the car for over an hour each way, and it's really getting annoying having my iPhone loose in the center console. I started researching what it would take to integrate it into the car and wanted to know what other's have done.
My thoughts were to have an integrated cradle which would charge the phone, provide audio out and also provide video out. I did a bit of searching, and found the below YouTube video of a guy who did exactly what I am thinking to his Acura TL.
From what I can see, ProClip item #s 853093 and 915246 will allow me to mount the iPhone, but I'm not sure where to get a cable which will provide A/V out and charging capabilities, and also how to splice into the audio and video of the factory unit.
For audio, I suppose I can tap into the XM as sugested here, but how can I tap into the video? It looks like the guy in the video below tapped into his GPS map video stream, and when the iPhone sends a video signal, it interrupts the GPS video and display's the phone's.
Anyone have any idea how to do this on our cars: Which cable to buy and which wires to splice?
Thanks,
Thomas.
21 - 40 of 53 Posts
Thanks for the info Heavy, sounds like the USA Spec Adapter might solve the config issues I'm facing now.
I picked up an Apple A/V cable and am using it to get audio into the unit. I soldered wires to the NAV harness and installed female RCA connectors in the side of the glovebox. I also permanently installed a USB connection in the back of the glovebox and hooked it to the 12v power of the cig lighter. Then I ran the Apple cable between the center stack and into the glovebox to plug in to these connections. (I would post pics right now, but my Wife left our camera in Houston :()
This is working well, except for 2 annoyances:
  • When I play a video on the iPhone, it does not display. I assume this is because it expects the video out to be plugged into something.
  • All audio comes out of my speakers except phone calls?!
The 2nd one is the most annoying. Even the touch tone sounds come from the car speakers, but as soon as a connection is made, the audio switches over to the iPhone speakers.
Not sure how to fix these issues yet without spending an additional $200 on an integration kit. I'm wondering if I jailbreak the phone if there's some software I can use to change how the video and telephone audio function?
Thomas.
I have to try out all the phone functions, as well. I wonder if there is some type of setting to use external speakers in speakerphone mode. Have to play a little more. My biggest concern was the music but it would be nice for the audio on the phone portion to work with the stereo.
All of my Internet searches are ending with the conclusion the iPhone doesn't support call audio through the dock connector, but it seems Apple has a dock which does?
I wonder if the new iPhone firmware due to release soon will solve this issue?
Thomas.
Any progress? I would like to see a video of V for Vendette's head unit alteration as well.
I opted to get a rear mounted touchscreen DVD on an armrest mount that lets it flex forward for front seat manipulation. Paid and shipped so I still have to give it a full review. Looks to be a decent option. I wanted to get video out of the iPod touch/iPhone, but, I have not yet found a good cable that breaks out the video since it requires a decoder chip. I wish they had some sort of pass through with an RCA video out. And, to further quell the need for the front screen modification, the kids in the back could not view the front screen very well so this seemed like a solid alternative.
3
I did get the dock installation finished up, but still haven't found a way to get video into the NAV unit. The only "gotchya" on this was I had to grind down the apple cable connector's sides a bit to get it to fit into the ProClip dock. This is because the dock is made for a cable which has squeezable sides to release the cable from the phone, and the apple A/V cable doesn't have those. It took about 2.5 seconds to do it with a bench grinder ....
Here are a few pics of the completed setup. I used a sharpie to color the visible portion of the cable, and it doesn't look too bad; although the camera flash really makes it look strange?
In the glovebox is an iPhone 3g USB auto adapter permenantly installed to constant 12v, so I can charge even when the car is not running. On the left side I drilled 3 small holes and mounted female RCA connectors for audio/video, although the video is not hooked up due to reason stated above.
All in all, I am pleased with the setup. The 2 things still bugging me are the video input, and more importantly, call audio not routing through the dock connector. For now, I wear my bluetooth earpiece when driving, but I would really like an integrated solution. One idea I am considering is installing a bluetooth adapter in the glovebox and taping it into the RCA audio. This way, the call audio would route through the speakers and all other iPhone audio would be muted.
Oh, and Heavy, the apple cable does a great job of breaking out the video. The cable has a USB for charging, 2 RCA for r/l audio, and a 3rd RCA for video. I tested it on my entertainment center, and it works perfectly. If you're just looking for a cable to give you RCA video, this one does it very well.
Thomas.
Thomas.
There are two ProClip options for the cradle. The one you purchased with the cable mount option (built on the standard Kensington cable) and one with a pass-through so that you plug your cable into the bottom of the cradle instead of the iPod itself. Then, no adjustments to any cable are necessary.
I do have the AV cable with the standard output, but, I want to still keep the standard dock cable and have the video broken out. The Dice dock has a video output break out as described but without the decoder chip. It worked great with my Video Ipod in the Mazda.
The iPhone speakerphone thing is interesting. If you had a blue tooth module with FM, you would get music over the speakers AND you would get inbound phone calls over the speaker, as well. Supposedly, if you plug in the AV cable at the top of the phone, the speakerphone output is sent out that way since you could be using earphones. I think I will pick up a bluetooth speakerphone with mic that mounts on the visor. The BlueAnt Supertooth 3 looks interesting and well reviewed. It would allow you to listen to music and then when a call comes in, turn down the music and announces who is calling. All you say is "OK" to answer the phone. Pretty slick.
Ya, I considered both of these and decided on the cable mount because I didn't want the passthrough and cable connector end sticking down from the cradle. Maybe I'm a bit picky, but I think the cable mount option looks cleaner.
This is true, but I have a hardwire connection to the head unit now, so I was just planning to get a bluetooth unit which has audio out and Y it into the inputs I installed in the glovebox. The trick I suppose is figuring out if I can tap into the onstar mic or continue to use the iPhone's built in mic.
This is true, and is what I do from time to time when I'm driving with the windows down. It's just a pain messing with the wires.
That looks pretty cool! Let me know how it works for you.
Thomas.
I like how you have the cables in the glove box. It looks pretty slick. I wonder if there is a bluetooth module that would has a stereo output. That might be a good approach, as well.
Yes, the cable is cleaner but if you had one of the really big cables that come with the iPod interface kits, like the USSpec one, it would never squeeze in there. But, since you were using the AV cable, it only took a little bit of manipulation to get it through. Just thought I would mention the option. The pass through is similar to the Dice, but the Dice has it at a 90 degree to the dock connector so it is easy to hide the cables.
Ahh, I think I see where you're going with this.
With the new iPhone 3.0 OS, we have stereo bluetooth transmission now, so if I'm not doing video I should be able to get rid of the cable all together and stick a bluetooth module (with stereo output) in the glovebox hooked up to the inputs. This should work well as long as I can figure out a mic solution.
Definitely worth a try ....
Yes, spot on. I am hunting around at the bluetooth options to see if there is one with a remote microphone and stereo output (not FM). Then, it could interface with the RCA inputs and I could locate the mic somewhere on the dash, likely at the top somewhere in the guages. Then, you have stereo interface for music and speakerphone as well as a more private location for the microphone. The announcements and voice activation should still work.
Now, the DVD NAV screen is a whole other animal to tackle.
I have two items that I have on the way and will evaluate.
1) The Blueant Supertooth 3 module. This is a bluetooth speakerphone extension for the iPhone with voice activation and call announcement. It clips onto your visor or can mount elsewhere.
2) The Blackberry bluetooth stereo gateway. This is a small device that connects to your stereo or adapter and allows you to stream audio from a A2DP compliant source (iPhone). It is also USB powered so you can easily find a power adapter for the car. With this, you can listen to music AND use your car speakers to listen to calls. The trick will be to position the iPhone built in microphone in a position that picks up your voice properly in the car.
So, I will report back on the working of both. I like Option 2 since it is basically invisible within the car. In Stoopalini's case, it could mount in or behind the glove box and all the iPhone would now neeed is in car charging. Additionally, those with iPod Touches could update to the new firmware that turns on the bluetooth capability. Could be very slick .
Dave
I got home tonight and the DVD I ordered had arrived so I decided to install it. Pretty straightforward. The CTS lends itself well to the install due to the armrest hinge. I simply mounted the DVD bracket to this source. I could have got the touchscreen version, but, the DVD buttons were silver and the design looked very cheap. This one matched a little better with the V interior decor and had a more solid feel. My kids love it. First picture is the DVD in viewing mode and the second is folded down in storage mode. The screen can flip up and down as well, so that you can position it any convenient way. It is pretty slick and the screen is nice and sharp.
It is a standard fare with the FM and IR output.I have a couple of IR headphones for the kids so I can drive in peace or I can play it over the radio. I like that I can pull it forward get the DVD loaded and running and then push it back to view position. Kind of handy but not as handy as using the iPhone to push the video. That is the next step. The video input cable is already run to the front by the iPhone ready to accept the video out signal. That is the next step.
damn man thats sick can i get some more info on what u used to do this thanks
anyone ever heard anything about a gn lockpick? Someone told me about this but haven't had time to research it...
I found some wholesale places to order overseas, but, I found someone with good eBay feedback selling them from China. This is the one I used:
http://cgi.ebay.com/New-7-LCD-Car-C...trkparms=65:12|66:2|39:1|72:1234|293:1|294:50
To my front door for $190. And, now that I have had it in place for a bit, the DVD mechanism is solid, does not skip and has no problems ready dual layers at all (Disney ones are usually the best test).
There are two endcaps on the armrest that pop off. Use these to mount the DVD arms. You can use mounting tape, but, it may or may not hold solidly enough. I drilled two small holes in each and mounted the bracket. Easily fixed if I decided not to use the DVD player. Second, since the seats are so close to armrest, even the few extra millimeters of thickness on the end caps may cause some rubbing with the seats. Heck, even the armrests run a bit when the seat is back. Just use a little bit of velcro stripping, softside, to shield any rubbing by mounting it on the leading edge that may come in contact with the seat. The cable just routes through the center console to the front where I tapped in to the cigarette ligher power. Very simple install. It took just under an hour.
I looked into that, as well. The DVD Nav we have is not one of the two models supported.
Well, the stereo gateway did not work as expected. It can stream audio nicely and the rings are now over the speaker but as soon as I pick up the call, it uses the iPhone speaker. Yuck. It needs to register as a headset, as far as I can tell, to send the speaker output to an external source. Sony has one that is a handsfree kit and has the mini-stereo output. Might have to try that one.
Heavy - Very nice!!
Thanks, it's a work in progress :)
More to come.
Wait im actualy very interested in this iphone plugged with the car how much can i get this for or can someone find me a deal on eBay
21 - 40 of 53 Posts
