1 - 16 of 16 Posts
2008 Cadillac STS
Since my 2008 STS is a two ton Verizon cell phone is it possible to access the Internet and display it on the NAV screen (with LockPick or ?)? I would like to check E-mail, pay bills online, play with my stocks, Etc.
OR
Perhaps even better, is there a way to link a Bluetooth, G3 cell phone to the NAV display? Even the iPhone display is too small and I don't want to drag a laptop around if I don't have to.
I would of course only do any of this while safely parked after purchasing an appropriate amount of McCrap at the drive thru window.
none
OR
No:tisk:
It can't even download phone names/numbers. If it can't do that, it is not capable of transferring more complictaed info.:annoyed:
2 Cadillac STS 1SG W/NAV
you can view it on the display if you have your lockpick, I have my sling box hooked up to my security cameras and my dish network and I can view it on my display
2008 STS - Grey/Black Northstar NAV
With Lockpick (if you need while moving), I would think it could display anything with composite (yellow RCA) connector in the AUX Vid port.
2006 STS 1SG & 2007 STS 1SE
Using your laptop's yellow RCA connector (baseband video) will work but depending on the hardware, you may encounter a situation where you only get a portion of the screen and have to scroll within that window - no fun. Changing the PC's screen resolution can help.
Typically laptops use a function key to control multiple video display's. On the Dell I'm at right now, it's <Function><F8>. If you're not familar with your computer's video capabilities, check out the manufacturers website for your model before starting. You can save a lot of time and not mess yourself up.
Have fun!
14 CTS Vsport Black Tricoat/black, 16 Escalade Premium Lux Gray on Kona.
So you want to hook up a computer - which is more hardware, through RCA - one of the worst forms of hookup for a high resolution device, an expect to be able to do anything with it? For video, it's fine, but for computer work, why not just uh... use the laptop screen. Unless you have a 7" laptop, every laptop out there is going to have a bigger, brighter, higher resolution display built in. Any output you get will be blurry at best.
The correct answer to the original question is: no.
Hey! I took the question as "Could I ..." not "Should I ...":rolleyes:
Too bad we don't have a higher resolution input than analog video. The maximum usable in NTSC (the now obsolete US format) is 485 lines. I don't know the specs of the STS-Denso electronics & display but we could have as little as 220 lines of resolution.:p
2008 Cadillac STS
Discussion Starter #11
Thanks for the information guys. I checked with LockPick and got about the same answer. I guess I'll have to settle for an iPhone or something similar.
Either way thats so low of a resolution, and remember it's an interlaced input so you have to halve that number. You'll have scrolling lines all over. Bleh!
Thank you Lord for not allowing some knuclehead coming at me in an STS while on the Internet.........:hide: I'm already dodging the Texters, the cell phone users, the tweeters, the DVD users.......:annoyed:
2006 STS N* 1SE
... I'm already dodging the Texters, the cell phone users, the tweeters, the DVD users.......:annoyed:
Reminds of a drive back to Illinois from the Wisconsin Dells from several years ago. I started catching a group of cars that were struggling to make the speed limit. As I weaved my way through them I finally figured out why.
I closed in on a pickup and noticed he was drifting in/out of his lane quite a bit. I became trapped behind him for a couple miles, and then... A second person 'appeared' from out of nowhere in the front seat. The driver finally settled down and kept it one lane. Ahh, now that's the original meaning of a distracted driver. :lildevil:
1 - 16 of 16 Posts
