1 - 14 of 14 Posts
1999 STS - diamond white
So what's wrong this time? The STS doesn't always start right away. Cranks fine, just takes a few seconds to fire up once in a while. It has backfire/popped a couple times while trying to start. Today the car stalled as i was coming off of the highway and on to a right hand clover leaf exit.
I replaced the crank position sensors a year or so ago. Had a bad coil a couple weeks ago. Cleaned the TPS, throttle body and MAF. Has new Motorcraft plug wires. Also replaced the FPR. Could it be a fuel pump? No codes. No CEL.
Yup. :yup: Check your fuel pressure.
I'd be happy if a pump fixed it, but I wouldn't want to find out it didn't. I have about 1\2 tank of gas to drain. I'm going to check the pressure and replace the filter first. It's original.
Here's a related question: The local AC Delco reseller has an AC Delco fuel filter for $21 and a Hastings for $13. I always thought Hastings was a good brand. Is AC Delco worth 40% more in price?
Autozone has Fram for $13 and Duralast for $10.50
I don't know what to say about the fuel filter. I would guess one is as good as the next.
I ended up with Fram. The STS filter is about half the size of the one I just put in my Focus!
I'll see how it goes this weekend. If it still acts up I guess a fuel pump is next. At least there's an access panel in the trunk so I don't have to drain and drop the gas tank.
Interesting AC Delco video on Rockauto about their pumps. Shows the quality difference between them and aftermarket parts.
Replaced the fuel filter and so far it starts right up. Hasn't stalled yet. The wife called today to say it "popped" when she started it. Sounds like timing or does it? No codes. Dirty injectors?
No, that's not timing. Timing is controlled electronically by the PCM.
I have found that if I released the key to quickly I could get that "pop" now and then.
Seems to me a vacuum leak can cause that as well if I remember correctly.
I get the occasional pop from my 98. Like Ranger said not unusual and i believe i have a vac leak also.
Discussion Starter #10
I still have the hard starting. Wouldn't a vacuum leak affect the idle? Mine is smooth once it starts.
Yeah, usually a vacuum leak will affect the idle.
Rule it out anyway. Spray some Brakleen around the manifold base, TB mount and vacuum line connections. Simple and easy. If you get no RPM increase, you can rule out vacuum.
Discussion Starter #12
I removed the fuel pump tonight. It wasn't very hard with the trunk access panel. The pump looked okay. The fuel looked clean. No rust in the tank as far as I could tell.. I couldn't bring myself to ordering a new one. It doesn't exhibit the usual fuel pump symptoms; surging, lack of power under hard accell etc. Maybe it's something like an EGR. I'll keep looking. Maybe it's the FPR I replaced recently when it was running bad. It turned out to be a bad coil instead. Maybe now I created this problem with the new FPR. <sigh>
You can't tell a bad fuel pump by looking at it. Fuel pressure test is the only way. Did you ever check yours?
Discussion Starter #14
Yeah. It was good. I just wanted to be sure the pump wasn't getting clogged up or there was rust in the tank. It only stalled once when driving. otherwise it drives smooth up and down the power range. Frustrating.
I'm going to replace the rusted up lockring and close up the trunk space.
1 - 14 of 14 Posts
