interior lights
1075 Views 7 Replies 4 Participants Last post by  Caddy01DTS
Does anyone have a list of the interior bulb types on an 01 dts? Thanks.
1 - 8 of 8 Posts
Do a search of the forums for Owners Manual, and you can download an owners manual for your car. The bulbs should all be listed in it.
Thanks.
Now, does anyone know how to get the cover off? Right rear dome light.
BTW, I searched my owner's manual and didn't find anything about courtesy lights in the rear. Anyone know what size or type I need, and how to get the cover off without breaking it? The button is stuck in for some reason.
Can't post images but this may help.
1st is Bulb replacement, 2nd is the switch
<H1>Courtesy Lamp Replacement - Rear Quarter
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=462209&psdid=226&evc=sm#ss1-462209">Removal Procedure
  1. <LI type=1>With a flat bladed tool, carefully pull on the outboard edge of the courtesy lamp bezel in order to release the two courtesy lamp bezel clips from the courtesy lamp bezel. <LI type=1>Rotate the rear courtesy lamp switch counter clockwise in order to release the rear courtesy lamp switch from the bezel. <LI type=1>Remove the courtesy lamp bezel.
  2. Remove the courtesy lamp bulb from the courtesy lamp fixture.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=462209&psdid=226&evc=sm#ss2-462209">Installation Procedure
  1. <LI type=1>Install the courtesy lamp bulb in the bulb fixture. <LI type=1>Install the courtesy lamp switch to the courtesy lamp bezel. <LI type=1>Rotate the lamp switch in order to position the courtesy lamp switch wiring facing the outboard side of the courtesy lamp switch bezel. <LI type=1>Hook the inboard edge of the courtesy lamp bezel to the inboard edge of the headliner.
  2. Align the courtesy lamp bezel clips to the bulb fixture and snap the courtesy lamp bezel into place in order to engage the trim clips on the bezel.
</H1>Courtesy Lamp Switch Replacement - Rear Quarter
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=707883&psdid=226&evc=sm#ss1-707883">Removal Procedure
  1. <LI type=1>Remove the windshield pillar garnish molding. Refer to Garnish Molding Replacement - Windshield Pillar in Interior Trim. <LI type=1>Remove the center pillar garnish molding. Refer to Garnish Molding Replacement - Center Pillar in Interior Trim. <LI type=1>Remove the sail panel. Refer to Sail Panel Replacement in Interior Trim. <LI type=1>Remove the assist handle. Refer to Assist Handle Replacement in Interior Trim.
    Notice
    Use care when removing or installing the headliner. Excessive bending will damage the headliner.
    <LI type=1>Lower the headliner in order to access the rear quarter lamp electrical connector (1).
    Important
    The electrical connector for the rear interior lamp is glued to the headliner.
    The electrical connector will need to reattached to the headliner, after repairs are completed, in order to ensure the connector does not rattle.
    <LI type=1>Carefully release the electrical connector (1) from the headliner. <LI type=1>Disconnect the rear quarter lamp electrical connector (1).
    <LI type=1>Carefully pull on the outboard edge of the rear quarter lamp bezel in order to release the two quarter lamp bezel clips.
    <LI type=1>Rotate the rear quarter lamp switch (1) counter clockwise in order to release the rear quarter lamp switch from the lamp bezel (2).
  2. Remove the quarter lamp switch (1).
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=707883&psdid=226&evc=sm#ss2-707883">Installation Procedure
  1. <LI type=1>Install the rear quarter lamp switch (1) to the rear quarter lamp bezel (2). <LI type=1>Rotate the rear quarter lamp switch (1) in order to position the rear quarter lamp switch wiring facing the outboard side of the quarter lamp switch bezel (2). <LI type=1>Install the rear quarter lamp switch button to the rear quarter lamp assembly. <LI type=1>Hook the inboard edge of the rear quarter lamp bezel (2) to the inboard edge of the headliner. <LI type=1>Align the rear quarter lamp bezel clips to the bulb fixture and snap the rear quarter lamp bezel (2) into place in order to engage the trim clips.
    <LI type=1>Connect the rear quarter lamp switch (2) electrical connector (1).
    Important
    The electrical connector will need to be reattached to the headliner, after repairs are completed, in order to ensure the electrical connector does not rattle.
    <LI type=1>Reattach the electrical connector (1) to the headliner. <LI type=1>Install the assist handle. Refer to Assist Handle Replacement in Interior Trim. <LI type=1>Install the sail panel. Refer to Sail Panel Replacement in Interior Trim. <LI type=1>Install the center pillar garnish molding. Refer to Garnish Molding Replacement - Center Pillar in Interior Trim.
  2. Install the windshield pillar garnish molding. Refer to Garnish Molding Replacement - Windshield Pillar in Interior Trim.
Thanks a million for the info, SurferTom..
1 - 8 of 8 Posts
