1993 Cadillac Fleetwood Brougham
In my 1993 Cadillac Fleetwood Brougham Interior lights stay on when the doors are closed.
Where exactly located the connector that is responsible for this. Is it in the door or in the interior area?
In this forum it was discussed, but it was not said exactly where this connector is located. Can you show in the diagram?
Thank you very much!
Assuming the headlight switch knob is not rotated fully counter clockwise by mistake, I would suspect the yellow 20 amp BODY fuse is blown. A blown fuse in that circuit would allow feed back to the dome light circuit. The body fuse provides power to the cigar light sockets. I've seen coins and tin foil in the sockets from non smokers causing a blown fuse.
95 FWB 81SDV 96 FWB 94 Fleetwood
Try this if your car has remote door locks... Unplug the module that controls the door locks. It is located under the third brake light. You get to it from inside the car. Pull off the cover for the brake light and it is under it. Pull it out and see how the lights work.
