1 - 20 of 25 Posts
'09 CTS-V Clack 6psd (manual), Recaro, Loaded...
Hey folks,
I hope this isn't a repeat topic (I did search) but I was wondering how the overall interior fit and finish is in your car.
1 minor thing that I've noticed is that the speaker grills do not sit flush in my car. This is noticeable on both the center channel and driver side speakers (one side sits higher than the other/not flush). I'm assuming that this is 5 minute fix but I have not tried yet. Does anyone else have this issue with their speaker covers?
Does anyone else have any weird fit and finish issues worth noting?
Thanks!
2011 CTS-V Coupe (Auto)
I have not had any problems with the fit and finish of the speaker grills, but I did have the "carbon fiber" trim piece left of the shifter start to raise up a bit (by 1-2mm) and the passenger side b pillar wasn't flush to the roof in comparison to the drivers side (by 3-4mm). I can be a bit anal retentive sometimes.... Both have been taken care of by the dealer and are fine now. Out side of those two fitment issues, the interior has been flawless.
I'm wondering if they (speaker grills) are a dealer prep thing and not a defect of the molding process then. I will say that it isn't really a subtle mis-alignment, there is a clear gap between the dash and leading edge of the cover.
In any event I'm going to pull them off tonight and see what I can see.
2009 CTS-V (Blue Diamond Manual/Recaros/Nav/Suede/Polished)
I haven't noticed anything on the interior, but on the exterior, I noticed the driver's door isn't quite flush with the passenger door at about door handle height. Something probably just needs to be adjusted, and I'll get it done the first time I have the car in, probably for my first set of rear tires.
I doubt they are a dealer prep item, I just went down to take a a couple of pictures of them for comparison. They are a little large, so it might take a bit for them to show up....
Direct links:
http://img4.imageshack.us/img4/7096/dsc01852e.jpg http://img4.imageshack.us/img4/6221/dsc01852zri.jpg http://img25.imageshack.us/img25/932/dsc01854c.jpg http://img6.imageshack.us/img6/1811/dsc01855vhc.jpg http://img9.imageshack.us/img9/3784/dsc01857a.jpg
If you are not able to figure it out tonight, you might want to just make an appointment with Covert Cadillac and they should be able to get it taken care of with out a hassle. My experience with their service department has only been first rate.
Hope this helps...
Thanks for going through all of the trouble to takes those pics!!!
Yours are definitely straighter than mine. I will not have time to look at them tonight actually but tomorrow for sure.
Thanks again!
2009 CTSv & 2006 STSv + 1991 SHO
Hey folks,
Thanks!
I've noticed the space/gap between the front dash and the doors doesn't seem to be consistant from driver to passenger side on some V's I've seen.
2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
I haven't gone over the interior with a fine-toothed comb yet on my car, but don't see any obvious fit and finish issues other than:
a) the Ultraview pop noted by others in another thread....very intermittent
b) if you push on the center console piece with the analog clock, it squeaks. Luckily, it doesn't rattle. I'm going to be installing wait4me's DVD/navi bypass soon and may place some extra felt back there while that panel is off to avoid a potential future rattle.
2011 GTR
I'm not happy with the fit and finish of this interior and have a few issues that I need to get to the dealer for. The passenger side pillar between front and rear doors: gap at the top. My driver side seat squeaks and makes noise which is very annoying. Maybe I'm anal retentive too, but this is a "Cadillac" - GM's premier line, and I thought the quality would be better. No issues like this whith my Z06 so I'm surprised about this car.
On a side note.... the ghost lights or whatever you want to call them that light up under the carbon fiber strips at night. Does the small one to the left of the radio and right of the steering column light up? If so, mine's burnt out and needs to be replaced.
Thanks,
Mark
The section between the steering wheel and the radio doesn't light up. I would guess because it is blocked from view for the most part.
Discussion Starter #12
So, today I went to an audio installer to have my radar detector hardwired and my windows tinted (looks much better btw) and they went ahead and straightened out the speakers for me (it would have been easy enough to do but since I was already there).
Other than that no obvious fit and finish issues that I've seen.
If you don't mind me asking, which audio installer did you take the car to, I have been toying with the idea of tinting the windows. I love the way a tinted black car looks, but I also like the amount of light that I get in the car, makes it feel open. Previously I had a car tinted at Custom Sounds back in 2003 and was happy with the work. Glad they got the speaker grills taken care of for you.
Discussion Starter #15
I went to Custom Sounds on S. Lamar and I'm happy with their work and the price. They did that and the radar hard wire in under 3 hours. It was also an off day for their tint guy, he agreed to come in around my schedule which says a lot by itself. This was the first time I have had dealings with them and I'm happy.
2009 CTS-V , 2010 SRX 2.8T
I'm having serious noises with the ultraview when its warm out...creaking, popping, etc. And also dash noise /creaking from the vent right of the nav on the passenger side. Its highly irritating and better get fixed. My jeep srt8 w/ 30k miles didnt ever make so much as a peep. And as someone noted for the "premier line" of gm to make a vehicle with so much noise is very disapointing....either that or some uaw workers decided it wasnt in their interest anymore to make a solid vehicle.
The lighting you are referring to is called Ambience Lighting. You will note that the section just to the right of the radio also does not light up. The reason has nothing to do with visibility. Both of these sections are directly above the AC outlets on the left and right of the radio. That is the reason that they are not illuminated.
Thank you, I do realize that the light the come from beneath the trim is called Ambient Lighting, and also that the area is the same as above the right central A/C vent, and that neither light up. I was just trying to quickly explain that the section in question is not supposed to be lit. But, I am glad you clarified in more detail what I was referring to.
~Matt.
2010 CTS-V, 2010 EXT, former 09 CTS-V, 06 EXT, 05 CTS-V
ok i have been looking for somewhere to vent about my fit and finish and finally found this post so here goes my dennis leary rant:
The caddie emblem in the center of the steering wheel is dented.
Both Pillar arms passenger and driver side stick out about 6 mm. I can actually see the metal frame of the car.
The carbon trim pieces next to my shifter are loose.
I have rattles in the headliner above the passenger and in back seat behind the driver. I have had my car in 5 times to fix the rattle and no dice yet. This last time in they pulled the entire headliner out and said a brace that went across the top car was cross threaded and not tight and that was causeing the rattle. They tapped the hole and put in an new screw so it's tight and said that would take care of it....nope! Still rattles.
I am so frustrated i want a new car. That along with some electrical issues that are screwy...see my sun roof post if you are interested...
I guess I expected more. I can't beleive I actually miss my 05 CTSV because everything worked on that one...i obviously like evreything about the new one if everything on the new one worked, you know?
1 - 20 of 25 Posts
