Instrumenten Panel Cluster
To my 94 Cadillac de Ville the instrument reading remains dark. The safety devices are examined, all into all functions go o.k. , evenly only no announcement.
Check your fuses. A bad fuse will keep the panels from working. Check your dimmer switch for your interior lights too, that could be a factor.
Re: Instrument Panel Cluster/digital display
1993 Fleetwood Brougham
I've a problem like this. The Digital speed/fuel display is completely out! I get all the side signals when the key is first turned on but no speed.
I have checked all the fuses and the single 5 amp one under the steering. I have checked all the lights and dimmers but to na avail.
The readings I get from the diagnostics point to 144 on the CCM, and 30,33,35,37 on the ABS/TC system. Could it be the main brain??:suspect:
Thanks for any pointers.
'94, '93 & '76 FWBs. '77 '79 & '73 CDVs, '65 Drop, '62 CDV
HI Zugy, Did you get this fixed and what was it? I've exactly the same thing on my 93 FWB
Thanks Nick
