2006 SRX and a 1998 Seville STS
Fuel Gauge and Temp Gauge are out but, speed and tach work. No data for the computer. Battery Light, Airbag Light, and Traction Control Light all lit. Cannot control brightness of cluster. Just confirming that it is the cluster and not a module? Do modules and or the IPC require programming? Please advise. Thanks in advance.
To me it looks like the cluster (DIC) itself or the ground system. Too many different systems to be one "module".
Behind the DIC check the main electrical connectors. There are two multi-ground boxes for the dash area, outboard of each footwell carpeted outer kick panel - studded to the fenderwell body metal. The grouped ground connectors in the box or the body stud ground have been known to cause troubles.
Thanks Sub... I will pull that apart this weekend. The grounding problem might explain some of the other intermitting issues as well. Example: Amp, Mirror, Seat Heater, Traction Control, Lights, AC, etc...
