Instructions on removing visors?
1661 Views 9 Replies 4 Participants Last post by  rblimas
hey guys, im lookin for an instruction manual on how to remove ur front two visors.
I know ive seen it on the net before, i just cant remember where.
Im lookin to put 2 screens in my visors and i know its not that easy to remove them.
so if anyone knows where this manual is, hit me up.
Thanks.
1 - 10 of 10 Posts
Driver's side, might be same for passenger. :alchi:
How do I remove the Driver-side Visor (with Homelink)
You have to remove the left front pillar molding (w/ speaker)
Then remove the small holder that holds the visor on the right
Then pop the center overhead console down from the ceiling
Then unscrew the three screws holding the visor on.
Then pull down on the roof liner carefully in that front corner until you can reach inside and pry the harness connector from the roof liner (it's glued). Becareful, the roofliner is fiberglass and will give you fiberglass splinters!
Once you pry the connector up, you then need to manipulate the connector loose (you can only fit one arm in there)
Then you just plug the new visor up to the old connector, and reconnect everything.
Thanks M sheri
Hello CTS guru's out there, home someone can help me. I am trying to install my visor with homelink. I think i've got half of it.
i've got this part done - You have to remove the left front pibllar molding (w/ speaker)
any pointers on this? how to remove holder? - Then remove the small holder that holds the visor on the right
i've found instruction for this on installing th radar detector - Then pop the center overhead console down from the ceiling
i've got this part done - Then unscrew the three screws holding the visor on.
didn't get this far - Then pull down on the roof liner carefully in that front corner until you can reach inside and pry the harness connector from the roof liner (it's glued). Becareful, the roofliner is fiberglass and will give you fiberglass splinters!
thx guys
bump:
how can i remove the small holder that holds the visor on the right? anyone!!!
i found it :) i guess with lil more light you are able to see more. There is little tab on holder, you open it and there is lil screw
rblimas,
what do you mean with screens? sorry
1 - 10 of 10 Posts
