Hi..can someone tell me which hard plastic vacuum lines that snap into the passenger side valve cover go to.. I know the brake booster goes into the in line check valve but i can't figure out where the plastic lines go since there is only one nipple on the check valve...any help would be appreciated..even a pic of your engine bay could help
Thanx
1999 catera
Catera 2000 & Catera 2001
There is no vacuum lines that go into valve covers in neither side. There is valve check hose that has 2 connectors for small lines, one goes to the splitter and from there to the heater box and to the auxiliary air valve from the other side, and third line goes to the box mounted on the bottom of the ram system, which is in front of the engine, between radiator.
Sent from my Pixel 3a using Tapatalk
That's exactly what I needed...Perfect thank you..
Also I was only talking about how at least on my catera the plastic lines snap into a couple channels on top of the valve cover for routing and hold down reasons..I didn't mean literally into the cover.
