1 - 9 of 9 Posts
STS
My car seems to run like crap unless i have some addative to the gas (spiting and sputtering) without addatives it feels as if it is misfiring, but I have no misfire codes coming up. I have 106,000 on it and havent replaced the coil packs before. The dealership said it sounds like injectors since it runs good with addatives but without it spits at high rpms. Is there a way to check injectors or maybee even the coil packs? or should I have them do their power flush on the injectors. does it realy work?
STS
The techron addative is the only thing that seems to work. Did yours have simular symptoms (running good with techron and awful without at higher speeds?) that techron seems to be the miracle cure, until i need more gas.
The best fuel additive I have found is made by a company called Lucas. It is a fuel injector cleaner. It is better than any petroleum or synthetic additive you will find. A general rule, "spitting and sputtering" are signs of a fuel problem, with exceptions, and sudden stalling are signs of an electrical problem.
STS
GOT it figured out, the shop I took it too months ago for some work somehow lost 3 of my 5 clips that hold my airbox closed, thus throwing off my mass air flow sensor,*RUNS GREAT FOR NOW* found this one out luckily by accident. Thanks for the input..
1 - 9 of 9 Posts
