I have an 05 CTS-V hardly driven (basically sits 77k miles) and started to get flashing check engine light. Pulled code and reads P0300 and after driven awhile it’ll change to P0304. I changed the spark plug and coil in bank 4 and swapped wires. Still no change. My next step is to swap injectors but I am having a hard time finding any “how to” vids or write-ups. Can anyone help me or point out any resources. Any additional help on the codes and misfire also greatly appreciated. Thanks in advance!
'93 SedanDeville 60 Special
Do this when engine is cold and by then fuel pressure will be down
There are 2 mounting bolts per fuel rail to remove from intake manifold
Disconnect the wiring connectors for the wire loom for that side's coil and injectors
You only need to lift rails high enough to get end of injectors out of intake, so should be no need to take fuel line from tank off the left rail
You will have to pull/yank up on the rail to get the injectors to come out of the intake
You will need some towels there as some fuel will come out
Pull the top of injector out of fuel rail
Each injector has a O-ring at both ends so make sure they still on injectors and not have come off
To install the ones you swap to prevent the O-rings from rolling over is put a drop of oil on each O-ring first
Watching that the end of each injector is pointing to the opening of intake set the fuel rail down, making sure injectors seated and O-rings did not roll and pinch.
And wiring connector of injectors pointing the correct direction as they were before taking them out
Tap each end of both rails to get injectors seated, remount the bolts but do not over torque them
Once all wiring connectors are plugged in, turn ign key ON, but do not start engine
This will get fuel pressure back up to rails (about 58 PSI) and check closely at all injectors that there are no leaks
Perfect, it’s a lot easier than I thought. I’m glad I do don’t have to remove the fuel line. Thanks for the fast and thorough reply. Greatly appreciated!!!
You're welcome,
and make sure you out a drop of oil on O-rings, so they do not roll over when installing the injectors
and the 2 male wiring pins of injectors are not bend when putting the wiring harness connectors on
If you're swapping injectors from one bank to the other, once pulling rails up with all the injectors still in them
I do is take like string and use the under hood latching hooks and swing rail up and to the left and then tie it
off and now rails are suspended up, so now easy working on all 8 injectors
2006 CTS-V
Pull the fuel pump fuse and crank the engine a few times to remove any pressure in the fuel system.
Use gloves and rags, you will make a mess.
I highly recommend you replace the fuel injector O-rings after you remove them, and remember to torque the bolts properly.
Alldatadiy is a cheap and awesome resource with step by step guides, I'd suggest getting an account. I think my last renewal was $36 for 3 years or something like that. It's been a while.
-Byron
