The injectors on my 93 Allante N* are super expensive so I was wondering if there's a lower cost alternative such as injectors from another brand of car?
The engine has 64k miles but I have not been able fix the hard warm start problems so I'm thinking it's probably injectors.
Symptoms:
Easy cold start
Easy warm start if started immediately after shutdown
Excessive cranking if engine sits for 15 minutes to 1 hour
Raw fuel smell from exhaust after excessive cranking :ill:
Poor city fuel economy (9-11 mpg)
Poor fuel economy at speeds under 80 mph
What I've done so far:
New AC Delco FPR
New wires
Regapped original spark plugs
New fuel filter
Ran Lucas fuel treatment through several tanks of fuel
Performed a fuel pressure test and got the following:
Cold engine - 0 psi
key on - 40 psi
5 minutes - 36 psi
25 minutes - 30 psi
105 minutes - 20 psi
Symptoms:
Easy cold start
New AC Delco FPR
New wires
New fuel filter
Cold engine - 0 psi
key on - 40 psi
5 minutes - 36 psi
25 minutes - 30 psi
