i wanna get a good amp what should i get ? and wat size is the back speaker the one big one in the trunk on a 03 Deville Base?
02 Seville, 04 SRX (sold), 96 Eldorado (sold), 99 DeVille (sold)
I would just look to find an amp that can be bridged down. Just make sure that you are getting one that is the right Ohms to work with your speakers and the stereo. You are probably going to need to spend $200 at minimum something decent enough to drive those. Word of advice, don't buy used.
'97 Seville STS
...depends on how fancy you want to get.
On one extreme, wire the voicecoils on each sub in parallel, so each sub is 2-ohms. Then wire the subs in parallel for a 1-ohm total. Use a class "D" digital mono block for efficient power, something like one of these:
http://www.rockfordfosgate.com/prod...ly_id=22&item_id=95253&locale=en_US&p_status=
http://www.rockfordfosgate.com/prod..._id=105&item_id=107999&locale=en_US&p_status=
On the other hand, you could run each sub with it's own class A full-range amp (better control & sound quality but less power efficient).
one of these on each sub could be stout:
http://www.cardomain.com/item/ROCT5002
Or more compact (but more $$$):
http://www.rockfordfosgate.com/prod..._id=106&item_id=107996&locale=en_US&p_status=
