While Im Driving My Car It Seemed Like The Battery Got Disconnected For A Minute Then Came Back On...And THen The Car Shut Off And When I Turned The Key No Lights Or Nothing Came On..So I Disconnected The Battery For A Few Minutes And Hooked At Back Up...Now The Lights And Everything Works But It Wont Click Over.....Could It Be A Bad Cell In The Battery....Or Could It Be The Starter Or Distributor If The Distributor Went Bad Would It Make The Car Turn Off...Or Could It Be THe Alternator....??:hmm:
1989 Sedan DeVille is now just a fond memory ....
If the battery cable connections at the battery are corroded the battery will not get recharged by the system. You need to disconnect and carefully check them, I had a Chevy Monza that fooled me once. The connections looked fine from the outside. I disconnected, cleaned and reconnected and that solved my problem then. Hopefully yours may be as simple.
You should also check your battery's fluid level. If the caps on the top of the battery can be removed, (I don't care if it's supposed to be "maintenace free" I believe that to be an oxymoron, a ploy for battery companies to sell more batteries) carefully pry the covers off and fill any low cells up to the bottom of the tube at the opening with distilled water.
Last, check the ground cable connections, the negative battery cable and the cable on the alternator. Check the cables and check/clean the connections at each end.
I have no idea what that small red wire goes to. Sorry.
