They said my oil sending unit needed to be replaced I didn't get it done my car runs great oil is good no leaks no issue so I went by napa auto and asked them how much was the part they couldn't find one they said do you mean oil pressure switch I said Im not sure they said oil sending unit .So my question is what does my car have and how would you know you where having a problem with it.
2007 CTS 3.6 >131k miles
It is the oil pressure switch. If it has a problem you will get a check engine light and a code (P0520 for most cars but I cannot confirm this for the Cad). If you have no check engine light I don't know how they could have determined it was bad. Also, I prefer to check the connection and wiring to the switch, and apply dielectric grease to the connections to rule out any such issues before replacing the part.
Oil sending unit, oil pressure switch, oil pressure sensor, etc., etc. - same critter but, depending on whether or not the vehicle has a gauge (moving needle) or icon (idiot light), the thing does different stuff.
Technically, an oil pressure switch turns off and on a light or icon in response to excessively low oil pressures. An oil pressure sending unit sends a variable voltage to a gauge, usually calibrated in psi but sometimes L - N - H (low, normal, high).
Have the car scanned at a local parts store. It has its own built-in diagnostic systems that check MANY things and keeps a record of faults and hiccups. Get the printout and use one of these links to further decipher any found codes.
Codes read out as a letter, 4 digits, a letter, like P 0305 C (Powertrain, miss detected, cylinder 5, Current).
P = Powertrain
B = Body
C = Chassis
U = power and data
0000
H = History - the fault has not been detected for X stat-run-drive events
C = Current - the fault is happening now.
Thank you for the feedback.Now that I know a little more Im going to have my son check the connection and stuff because I was wondering how they came up with that to since I was having no problems .
