N*Caddy wrote
At this moment it can not do anything other than accept a firmware disk and install it automatically.
The firmware for these units comes installed on a CD (CD not DVD) and has about 7.5 MB.
To install the firmware:
1. Get the firmware CD.
2. Turn off the ignition and open one door (your NAV unit should power OFF).
got a problem, I have it does not turn off, always active.What to do?
3. Turn the ignition ON (ACC) and in the very first 5 seconds after the NAV powers up press TILT. (Caution with no firmware the screen will NEVER retract back, so once you tilt the screen you need to install the firmware in order to retract the screen back).
4. Immediately after the screen tilts insert the firmware disk (the unit should pull the CD in). If no luck repeat step 2 and 3 just this time since the screen is already tilted you just insert the disk immediately after the unit power up.
5. With the disk in you can only eject it (using tilt) in the first ~20 seconds after power up (if you need for some reason to cancel the firmware install).
6. Once the CD is in the unit takes up to 1 min to read the disk and initiate the install procedure (just relax for the first minute or so is normal - looks like is frozen but in fact is doing stuff).
7. Approximatively 1 minute after firmware disk is inserted a progress bar will show up. The progress bar will take about 1 minute to get from 0 to 100%. If the disk is scratched/damaged or for some reason the unit can't read it in less than 1 minute after disk is inserted a message should show up with something like "wrong disk....". You need to restart unit (step 1 + 2) eject disk, insert (same or other) disk again.
8. Once the progress bar gets to 100% 3 beeps will be emitted, the screen will retract and you will be prompted with the Cadillac logo over the blue screen.
10. Your firmware is restored and you can resume the use of the NAV unit.
Why the firmware is lost in the first place?
The firmware is preserved in a memory that requires power to be maintained. The power is provided from a small (coin size) rechargeable battery internal to the NAV unit (kind of like the BIOS settings on a computer motherboard). This battery is recharged from your car battery and should be able to hold the firmware for years without external power. The problem is, in time the battery can not hold a charge, so it gets from years to no more than 2-3 seconds. This is especially if the car battery is disconnected/or dead for long periods of time (say you don't drive the car over the winter and the battery is old so by spring is already flat). But this only accelerates the process, in time no matter what the small internal battery does deteriorates. Even with a bad internal battery the firmware should still be stored as long as the car battery is connected. But one day for some reason you will disconnect the battery and in the following seconds you loose the firmware.
You can actually replace this internal battery (is like $1.99 retail) and you can have piece of mind that in the next 8-9 years is likely that your firmware in the unit will not vanish. It does involves removing the NAV unit from the car and dismantling half of it to get to the battery. Then soldering is required.
need to change the battery in a software update?
tech2 should see the radio when connected to a car?
possible to restore the software by using TIC2WEB?
