2000 Catera Sport
Everytime I remove my intake plenum I see oil inside it, in the throttle body, in the two small holes on back/ top of the throttle body, in the large intake hoses connected to the front of the throttle body and in the lower intake. I clean it all out and a week later when I remove the intake plenum, same thing. Its all coated in a thin layer of oil. Could this be a clogged breather box problem?
2000 Catera
Hey man I am having this same problem along with my motor turning over and will not fire. If this has something to do with no fire and you figured out the problem, I would greatly appreciate the info.
Platinum 2001 Cadillac Catera Sport
No ignition is usually the Crankcase Position Sensor (CPS). Read more in the stickies at the top of the page.
Catera 98 & 99
the crankcase breather would always have positive pressure, if it was clogged the vavle covers would blow.
i have the problem in my 99 that i just cleaned the breather and replaced the vavle covers. the only thing i can think why this is going on there could be to much oil or to much crankcase pressure.
