I am at 11.4 now. I am designing and developing a larger intercooler, heat exchanger, and casting a redesigned lid for the supercharger. Im thinking I may be able to squeek off some high 10s with this and a few other tweeks.
Those mods probably won't pick your ET up at all. Well, the cooler temps may help a little but the soak sets in quickly. I have a lid and it is a fail.I am at 11.4 now. I am designing and developing a larger intercooler, heat exchanger, and casting a redesigned lid for the supercharger. Im thinking I may be able to squeek off some high 10s with this and a few other tweeks.
I plan on using the Federals. Also I plan on fitting a larger intercooler in the stock brick's location, as well as properly shaping the lid for optimal distribution while maintaining laminar flow.Planning on using the Federal RPM 595 285/35/19 street tire or a drag radial tire for achieving your goal of 10's?
I plan on a larger surface area, rotating the direction of the water/charge rows, convert to a single pass vs. dual, increase fin density, round off end tanks for proper laminar air transition to runners, and many more changesIf the new brick is less restrictive on the air side he will see gains but not .4 sec. Drumstix and I have some experience with altering the lid, shape plays less of a role there than the shape of the floor (ie blower case) you may see some boost gain in combination with the new less restricted brick.
I did hear that the brick density was designed intentionaly dense to calm the air leaving the rotors by someone who has done a lot of testing.
I by no means am trying to discourage you. Its ideas like this that need testing to help us improve what we already have in regards to our 1.9l Eatons.
Good luck and keep us posted
Can't wait to see it.I plan on a larger surface area, rotating the direction of the water/charge rows, convert to a single pass vs. dual, increase fin density, round off end tanks for proper laminar air transition to runners, and many more changes
