Power Steering Pump Replacement
Removal Procedure
1. Place a drain pan under the power steering fluid reservoir.
2. Siphon the power steering fluid from the reservoir to prevent excessive spillage.
3. Remove the power steering pump pulley. Refer to Power Steering Pulley Replacement
4. Remove the gear inlet hose connection from the power steering pump.
5. Remove the fluid reservoir inlet hose clamp.
6. Remove the fluid reservoir inlet hose from the power steering pump.
7. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
8. Remove the engine shield.
9. Remove the AIR injection crossover pipe support bracket bolts.
10. Remove the AIR injection crossover pipe support bracket.
11. Remove the power steering pump bolts.
12. Remove the power steering pump.
