2 Great Decisions, 1 Not so great.... Welcome again and congrats..
GREAT DECISIONS
1. You are a Member of one of the best Forums out there with a lot of great members and a wealth of information...
2. You purchased an Extended Warrantee !
NOT SO GREAT
1. 2010 SRX......
I Purchased a 2010 Premium AWD 3.0 72K from Florida.... Still Under CPO ( Thank Goodness!!! ) Under body / Exterior and Interior looked like it just came from the showroom..... Road Rash Severe on 2 Rims. Had 2 new rims and 4 new tires installed.
Then one by one they started..... " CHECK EVERYTHING" !!! Read this form thoroughly!!!
1. Radio Defaults to DC, cannot save favorites. Prior owner never had it repaired. ( Replaced under CPO after a long conversation with local dealer )
2. Front Right Strut / Bushings / Sway Bar bushing ( Replaced CPO slight knocking noise at low speeds when cold )
3. Air Conditioning door control module failed ( Replaced CPO )
4. Front Axle Seals Leaking a bit. ( Both replaced CPO ) 3 visits, redone twice
5. OnStar Died ( Replaced Antenna CPO ) 2 Visits
6. Drive Shaft and Drive Shaft Supports replaced ( CPO ) 2 Visits to locate
7. Peddle Adjuster ( Brake and Gas ) stopped working after they fixed door control module. Replaced CPO
8. Sunroof Drain Hoses ( Replaced Recall )
9. Rear Strut assembly adjustment ( Recall )
10. Battery died ( If yours is original, search thread Amazon AGM Type 48. Still a great deal and one of the best Batteries out there under $130- Delivered to your door. ) Swap out is a snap
11. Check Engine Light ( New one as of this month ) Code Stated Bad Coil / Wire / Plug. CPO They just charged me for plug $2.75. Check Engine light came back on, back to dealer....
Purchased July 2014......
Oh number 12. needs to happen hopefully before December 2015, CPO ends.
Again, good luck!!!
Don't forget...
Change all your fluids.... Diff, Xfer, Brake, Power Steering, Transmission, Radiator.... Never know what prior owner did.... That's just me...
