Re: Hydra brakes??
Hello All: Haven't been on for a while, but I do have a question regarding 2003 CTS. I'm looking at buying rotors and pads on eBay and I see lots being flogged as " Hydra Brakes" that are zinc plated, drilled and slotted. There are several different models listed for my car, but they refer to "base model", "with sport", "standard suspension". My car has a "sport" mode for shifting, but nothing else relating to "sport". Would the seller know from my VIN which ones to send me? Thanks in advance.
Best Wishes, Brian
I definitely wouldn't trust an ebay vendor to be able to find the correct parts based on a VIN.
According to the 2003 CTS build sheet -
http://www.cadillacfaq.com/faq/answers/pdf/2003rpo.pdf - there is only 1 code for the brakes (JL9). Later model years had upgraded (JE5) brakes that came with some of the option packages, but 2003 didn't have that (according to the RPO codes on the build sheet). So, the ebay ad is probably just listing all '03 - '07 V6 CTSs together, when in fact not all the model years had those options. (Which takes me back to my point about not trusting an ebay vendor to find parts based on VIN, since they don't even know enough to know that the option codes weren't the same for all of those years.)
Interestingly enough, although there should be only one brake package for 2003, on rockauto.com I see a number of manufacturers selling two different rotors. What's weird is that they're different part numbers, but they're the same dimensions.
For example...
- Centric 12162070 and 12162069 - both 11.93" diameter, but one says it's 3# heavier than the other
- ACDelco 18A1477A and 18A1752A - both 11.92" diameter
- Bendix PRT5449 and PRT5593 - both 303mm (11.93") diameter
(No idea on the weights on the ACDelco and Bendix parts, only Centric lists the weight.) I may buy 1 of each using Amazon Prime just so I can compare them and ship 'em back.
If you don't have the v it has the passive gas shocks
Not sure what that has to do with him looking for the proper brake rotors.
I would avoid the eBay packages unless it's from a trusted brand/seller.
Agreed. Just pick up some good, plain (non slotted, non drilled) rotors from Rock Auto or Amazon. (I often look up parts on Rock Auto, since they have a good parts search, and then find the same part number on Amazon to get a better price and free 2-day Prime shipping.)
