1 - 19 of 19 Posts
´67 Eldorado, ´96 Eldorado
Well, HVAC controller in my Eldo doesnt work anymore :crying:. OK, i can live without AC in winter, but also blower fan doesnt work :crying2: and this is no good at all.
I want to order it from AutopartsStreet
I am only confused, cause here it is priced $184.
Same part in RockAuto costs $495
So my question is - are they identical?
Rockauto: OEM #16137740 / ACDelco #1572868
AutopartStreet: OEM #16137740 / ACDelco #1571789
Or it is there some kind of difference (and i dont mean in price :eyebrow: )
My car is 1990 Eldorado, 4,5L MFI (vin 3)
Or has anyone here this part laying in your garage? :D
I must order this part from US, because our dealer want from it no less, than $850
No, its plastic box with two connectors - one electrical and other vacuum. and in top some kind of "arm" (electric motor)
2005 CTS-V, 1994 Infiniti Q45
Well..... Id get the one from parts america, they seem reputible.... Do they have a partsestonia??? :histeric: Sorry....
Anyway, Id take the thing apart and see if you can see any burnt out electrical connections...... On my Q, its common for the HVAC control unit to burn out, and its a solder joint that usually fails..... easy to spot also.....
Discussion Starter · #5 · (Edited)
Thanks Wes, i´ll try those connections tomorrow. In partsamerica, they dont have HVAC controller (at least to ´90 Eldo), and they dont ship to other side of globe also..
But can you tell me about those part numbers?
About partsestonia - we have here only 1,5 mil population, so its no point to open here partsshop :yup:
Edit: Any help???
Id get the one from autoparts street.... If they list the same part number, its gotta be the same.... Make sure they have a good return policy, that way if it doesnt work you can return it......
I have the next few days off, I could look and see if I could find one for you!!! Although, I would have to ship it oversea.....
Thanks, Elwesso - i looked those connections too - they are good... :crying:
:thumbsup:
Get to ordering.... And tell us what you come up with.......
The head unit is working, right???
Discussion Starter · #10 ·
elwesso said:
:thumbsup:
Yes, head unit is OK, and blower power module too, no shorts/opens...
Sometimes its sucks, to have one and only car in your country... :(
And other thing - i cant find proper garage to my new(old) beauty - 67 Eldo :D We have here so small garages - hell, only little ricers fits there - old russian standards....
OK, beer time, i think :histeric:
Discussion Starter · #11 ·
Well, i ordered it and i get it probably in three weeks....
S***, we have almost winter here :annoyed:
Yeah, im sure...... Here in indiana its getting a little frigid also..... Right now its 9:50pm and its 33*F......
Discussion Starter · #13 ·
OK, i got controller - everything working like dream now!
And of course murphys law - tomorrow we have 10 degrees(C) :disappoin - almost summer again :coolgleam
Glad you got it back going again!!!!
Where did you end up getting it?
Also.... If you saved the old controlller, Id break it open and see if you can tell if anything went wrong......
Discussion Starter · #16 ·
I get it from junk yard & shop in Finland - only 50 bucks :bouncy: . It is not new, but it working!
I open old controller too - there is only few microchips and vacuum actuators (?). Probably one chip went bad.
But i started my ´67 Eldos restoration(today i take apart hood and fenders - to get more space to work with engine) and i think, i am start asking lots of (silly)questions about it too - i found one vacuum hose and i dont know, where it must connect. I´ll try to take pictures, so maybe you can help me out...
This car has been sitting last 10 years in garage and i dont want to start engine right now - it can be wery expensive repair, if something goes wrong.:suspense:
First i try to clean it, new oils, belts and filters...
1982 Eldorado Biarritz
I have a 1982 Eldorado with the HT-4100 small-block V-8.
As far as the blower motor is concerned, mine also suddenly stopped working, despite the fact that my HVAC and vacuum-actuated bypass dampers work just fine (I can hear them). When I attempted to locate either a fuse or a fan motor relay, I could find none listed in the owner's manual.
Now, the question is, are these fan motor fuses/relays part of the programmer box located on the firewall behind the glove compartment lining?
For obvious reasons, I would like to confirm this approach first before tearing the out blower motor assembly itself from the engine side.
2010 DTS
It has been a long tme since I've been under the hood of an HT4100 but as I recall there should be a reistor module on top of the HVAC housing on the firewall. It is mounted there and the module itself actually is in the air streem inside the box for cooling. I believe that is what needs to be replaced.
1 - 19 of 19 Posts
