1 - 10 of 10 Posts
´67 Eldorado, ´96 Eldorado
hvac controller - is it repairable?
in my car climate goes week ago crazy - its blow hot air between 16 - 22°C;
then between 24 - 28°C its allmost normal, and then between 28-32°C again blows hot as hell.
Does enybody knows about this failure?
And computer does´nt tell any error code...
Oh, yes - car is 1990 Eldorado
And summer is coming - i really need cold air into my car :mad:
2005 CTS-V, 1994 Infiniti Q45
About the only way to do it would be to hook it up to a TechII (dealers have them) and it can tell if the sensor is good or not (unless it is still reading correctly)
Still wouldnt be a bad idea to hook it up to a techII, it can do a test on the entire car to see if everything is running right.
Discussion Starter · #9 ·
...Still wouldnt be a bad idea to hook it up to a techII, it can do a test on the entire car to see if everything is running right. [/B]
OK, thanks - i dont need tech II, because OBD in my car shows all sensors readings in information display...
I ´m test it right away...
Thanks again!
yes that is true, but using a TechII makes things a whole heck of a lot easier!!
1 - 10 of 10 Posts
