Hub caps
I have a 1984 Biaritz Cadillac convertible, vin #1G6AL6789EE671707. The car has wire wheels. Is there a specific tool to remove the main wheel cover after removing the Cadillac emblem hub cap? It looks like a anti-thief lug nut. I need to know this asap. Thank you very much. Dale
1993 STS, 1997 STS, 2002 SLS, 2007 CTS 3.6
Re: Hub caps
You are corrct it is an anti theft device, my 86 Deville has the same thing, I could not find one so I had to take a chisel and hammer to get them of and than replaced with a regular nut the same size.
Hope this helps good luck
Re: Hub caps
There are a couple designs for these hubcap locks:
1. An anti-theft "bolt", approx. 1/2" in diameter that screws into a female hold-down attached to two or three lugnuts.
2. An anti-theft "nut", approx. 1" in diameter that screws onto a male hod-down attached to two or three lugnuts.
The tool for the "bolts" is approx. 1/2"-5/8" in diameter, and the one for the "nuts" is approx. 1" in diameter. They DO look like a deep socket with a handle attached. Both the "nut" and "bolt" type are color-coded. There is a letter stamped into the edge of the nuts that identifies the color code along with them being painted that color. The bolt type are just painted and have no stamping as I recall. Both CAN be removed with a good pair of large needle-nose Vise-Grips if necessary but you SHOULD be able to obtain the actual "key" (removal tool) at a junk yard. There are also "universal" retainer kits available from aftermarket companies such as Becker Hubcaps. The OEM retainers were made by "Norris Industries" as I recall, you may also be able to buy them direct still.
bob2231 said:
My 87 Eldo had something that looked like a large deep socket with a t-handle on it. You should be able to find one at a junkyard fairly easy. Good luck.
Thank you very much, I am glad it isn't something exotic and hard to find. We have plenty of junk yards around here. Thanks again.
Dale
