1 - 10 of 10 Posts
hi . what do i to disable the annoying drls on 1996sed. deville...and how do i turn the drls back on. thanks for any feedback. Dm
Never tried it but I would start by removing the fuse in the engine bay fuse panel marked "DRL". If that just disables the DRL relay, you've got your easy control.
2005 CTS-V, 1994 Infiniti Q45
I remember that one of my dads GM friends said that, on the late 90s tahoes, you could just slightly press on the Ebrake..... Just a smidge, not enough to engage it or make the light come on, but it worked like a dream to turn off the DRL......
1984 Fleetwood Brougham coupe
There should be a fuse in the fuse box that you can remove and the lights are off.
*nevermind I just now saw what Katshot wrote.
2003 Cadillac DeVille
lol I did that in the drive in! Just pressed the ebrake down lightly and ti shuts off the DRL's! Good ol GMC
Discussion Starter · #6 ·
Guys Guys don't wonder off my subject... what i need is not you to tell me how to kill the fuse, there is no such thing as the DRL fuse on Sedan Deville 96.
I need the computer codes and menus. Does any 1 know the cut off code for the DRLs?
Somebody that knows what they are talking about please reply :)
According to a couple schematics I have and one fuse box diagram from Cadillac, YOU DO HAVE A DRL FUSE. And I'm not aware of any computer codes to turn them off. What computer codes?
This implys that you want to know how to turn on/off the DRLs........
Now I dont know what you were thinking (or if) on your first post..... IE you accidentally posted something you didnt mean to.... I believe we answered your question perfect for what you asked.....
Question..... Why would you want to disable the DRLs if there arent any..... Or do you want to have the OBD command to ENABLE the lights.....
I am really confused by what you are asking..... :bonkers: :confused:
Discussion Starter · #9 ·
OBD command to ENABLE and Disable DRLs
i know there is 1. just as there is one to disable automatic doorlocks
thanks
Ps where is that fuse located? cause its not in the main underhood fuse box... is labled are u sure its labeled - DRL fuse?
thanks
I'm guessing you're talking about the IPC override options. Unfortunately, there is NOT one for the DRL system. I would suggest you check your owner's manual, maybe there's something in there about it. As for the DRL fuse position, check the attached picture. The top left fuse is the DRL fuse.
1 - 10 of 10 Posts
