May 10, 2012:
I had a fellow gearhead from work come over this evening and we got the heads torqued down and valvetrain installed. Progress!
May 26, 2012:
Progress is being made this weekend. Basically, because I'm a huge procrastinating moron, I'm getting down to crunch time. I'm moving in a month, and right now I'm attending an extremely intensive course of study in preparation for command, which keeps me at work 12-14hr per day during the week, plus time on the weekends. Not a whole lot of free time to play with.
So, with that said, I really want to get the engine in the car this weekend. Other than one small hiccup - where the frack did I put all the flywheel bolts?!?!
- I think I'm on track. As discussed before, the heads are on and torqued. A couple nights ago I installed the front cover loosely, awaiting install of the ATI damper. (The FSM has you use a special tool to ensure the front main seal in the front cover is properly centered on the crank snout. Without that tool, it appears the "normal" method on the internet is to install the front cover loosely, then install the crank damper, which helps to center the front cover, then tighten up the front cover bolts.) The motor mounts are installed on the engine.
The big job today was fighting with the wiring harness that goes over and around the top of the engine. As I said much earlier in this thread, the FSM method is to drop the engine out the bottom of the car, so the wiring harness on top of the engine isn't a concern. However, if you're pulling the engine out the top, the harness is a big problem. Imagine a 3/4 - 1" thick bundle of wires in a rectangular loop sitting on top of the engine. At each front corner, thick bundles run down to the A/C, ABS, PS, fans, alternator, etc. And at the bottom of the radiator support, a thick bundle runs from one side to the other, making a continuous vertical loop of wiring at the front of the engine, which is connected to the continuous horizontal loop of wiring that sits on top of the engine. And then at the rear, there are two legs that go back along either side of the transmission, so there's no easy way to move the damn harness out of the way! This picture gives a pretty good idea of where the harness goes:
When I pulled the dead engine, I had already removed the heads. With some stretching and cursing, I was juuuust able to pull the engine up through the horizontal loop of wiring. But with the new engine, I've already installed the heads (since I figured it would be easier with the engine out of the car), so that ain't gonna work - the engine is too wide fit down through that loop. Today I was under the car tracing the harnesses along either side of the tranny, disconnecting the various sensors and labeling everything, then pulling both harnesses into the engine bay. At that point I was able to flop the entire horizontal loop and the two rearward legs over the radiator, moving the harness out of the way of the soon-to-be-lowered-in engine. Hooray!
Tomorrow morning, assuming I can find all of the damn flywheel bolts, I'll pull the engine off the stand and install the flywheel and clutch. I also want to make a heat shield for the starter with some sheet aluminum - the starters are somewhat notorious for having issues with melting the harness connector and/or terminal plug, and that issue gets even worse with headers. The starter wiring harness on the car now is relatively new, as the old one failed on me during an event at VIR, but even this "new" one has clearly seen some heat already, so I want to shield it.
The next bit of fun will be repositioning the car. I live in a townhouse with a 2-car garage, but the garage is pretty shallow. With the V's rear bumper an inch or two from the garage door, I've probably got 2-1/2 feet or so at the front of the car - not enough room to maneuver the engine hoist. When I pulled the engine, I did it with the engine hoist on the side of the car, at a bit of an angle. That really made it a pain in the ass to control the fore-aft movement of the engine. To avoid that, I want to shift the car back a couple feet to give me more room to play in front of the car, so I can put the engine hoist in a more conventional position. That will require reinstalling the rear wheels, taking the rear off the jack stands, jacking up the front end to get if off the jack stands, rolling the car back, and putting the front back down on jack stands. I'll end up with the car hanging out the garage door, so hopefully I'm able to get the engine in without too much trouble, at which point I can get the engine hoist out of the way and move the car back forward. That also means that (obviously) the garage door has to stay open, which really sucks, since it's supposed to be in the 90s tomorrow. Normally the garage stays pretty cool due to the positioning of the house, but with the big double door open, methinks it'll be plenty warm in there.
May 26, 2012:
