1 - 2 of 2 Posts
81 Cadillac Seville
Does anybody know how to remove the piece of chrome trim on the bottom of my door. right below the rust. i want to repaint the door, i believe there is more rust under the chrome trim, any help would be great
thanks
Jon
1979 Coupe Deville
There should be a phillips-head screw at each end of the molding on the inside of the door lip/flange. Remove those (might need some penetrating oil to loosen them up). You should be able to carefully pry the molding off the plastic retainer clips once those two screws are removed.
1 - 2 of 2 Posts
