2015 XTS AWD - Black inside and out
I got the "Service Stability sys " message on the way to work. On my way home, it didn't display the message.
I didn't know how to pull codes until I searched tonight and found a few that say "history" after them.
The first was abs C1287 which is the steering wheel sensor right?
That is the important one. the others were because I was working on the car i think..
DDM U1713 history
IPC U1016 history
VTD B1327 history
so I think I cleared the abs code and this came up next: abs ID: 8111.
what does that mean?
do I need to clear all codes and start over? Will I see "history" after all codes once they are not displayed?
thanks
"ABS ID 8111" is a module serial number or ID. It is not a fault (DTC) code.
As Ranger posted, go ahead and clear the codes - then begin to keep a weekly log of what comes up. C or H. If a fault (or hiccup) is sensed it will set a C code, then if that particular fault does not occur for 3 drive cycles the code changes to H, and then self-clears after 40 clean drive cycles. (40 drive cycles was set as a typical commuter/shopper weekly routine: start, warmup, drive, stabilize, shut down.)
If you live in an emissions test area, do not reset codes within a few weeks of a scheduled test: the car needs to settle the systems down and set a "system ready" signal which the emissions test set detects. If the test set sees a "not ready" code, you fail the emissions test and have to come back after two or so weeks.
