1 - 13 of 13 Posts
None :(
The "grab bar" or "Oh Shit bar" over the rear driverside door that you can hang your dry cleaning from has pulled loose on the one side - I messed with it but am having issues getting it reinstalled properly anyone have experience putting these back on?
2004 CTS-V, 423 RWHP / 380 RWTQ
That thing is a PITA to get re-installed, I had to re-install both of them after wrapping my headliner in suede. It's been a while since I did it, if I remember correctly you need to make sure the oh shit bar brackets are perfectly aligned in order to get the bolt in, if you have them off by just a little bit it won't snug up against the car which won't allow the bolt to reach to hole. Not sure if that's any help, I remember that I screwed around with it for a long time with no success until I figured out that the bracket was lined up properly.
2010 Thunder Gray 6MT
Both of mine pulled out from passengers holding onto them. After getting them off I had to use larger screws. Problem solved.
2006 Cadillac CTS-V
That .PDF helped greatly. Mine has been off for months now and never got around to putting it back up (I never sit back there, why do I need to fix that?) Pretty slow at work so just went out and screwed it back on in minutes!
NONE
I also got a bigger screw and screwed it back in. It got ripped out by a passenger while I was doing a lap of the ring.
None :(
Discussion Starter #8
yeah, doesn't appear to be broken, just having issues getting the escutcheons to "snap" back into place and figured I was doing something wrong. What about the clip that these screw into? Mine sort of seems loose/floating around in there until I screw it in. I'll mess with it some more and see what I can do.
2006 CTS-V
I had mine ripped out by a passenger while I was doing a lap of the FDR, in NYC. LOL This guy is a longtime friend and golden glove boxer.
Then few months later, I run into him again, he sits on the other side in the back seat, and manages to pull it out while I was just cruising along. I just shook my head at him and told him he should have known better. LOL
Best way to put it back is to retap with a bit larger/thicker screw.
None :(
Discussion Starter #10
Thanks for the advice, but my issue is not that it is a stripped screw or stripped clip that can be solved with larger screw. I'll get some pics tonight & post up.
1 - 13 of 13 Posts
