Seville STS 2001, Eldorado 1997
I need to change Oxygen sensor for Seville SLS 96 which is located downstream of catalytic converter (there is a P0146 code). I tried to raise car using ramp both under front or back wheels but it was not feasible to get under car since catalyic converter is almost in between and it did not have much height for me to get under. Any idea what to do to raise the car. Also I was not able to see the oxygen sensor from the side. Is oxygen sensor on top of pipe?
John
1997 Seville STS, 2000 Seville STS
Its on the passenger side of the pipe about 6" behind the actual converter housing. There is a metal cover that is bolted to the botom of the car, that protects and supports the wire between the side of the car and the exhaust pipe.
Put the front end on ramps. Then jack the back end up and put it on jack stands.
Thank you MarK C and Ranger. It helps. I will try in couple of days.
John
