This is the passenger size of the radio, you must first take off the mounting brackets on each side, then remove the screens circled in red
You must also pop off the bezel around the radio, start on top and work your way down each side, and finally at the bottom (bottom is the hardest)
When you get the bezel popped off, disconnect the ribbon cable from the face.
Here is the bezel off the radio
Close up of the screws to remove to slide out the screen
Close up of the screws to remove to slide out the screen. The silver screws can't be mixed up with the gold screws, different lengths/materials
Screw to remove the top plate of the radio.
Pry on plate to remove it.
Remove these three screws to loosen the amp section of the amp.
Remove this screw to remove the antenna hook up.
Now remove these silver screws and the aluminum heatsink (all the silver screws are the same length, just don't get them mixed up with the gold screws)
Lift the board up and back
Remove these two screws on the back to allow the screen to slide forward.
You need to unplug these two plugs, one is 3 wires, other is 4. The circles indicate where they are plugged in. (this is probably only for tilting screen models)
