smh and i just ordered some 30'sI put 26's on last year and lost 2-3 mpg, takes a lot to turn them wheels.![]()
That's a good suggestion. The Dodge/Chrysler/Jeep SRTs come with either run-flats or spare tire repair kits and no spare tires to save weight...for performance, but it works for gas mileage too.One way to shed about 75 pounds is to remove the spare. I keep a tire plug kit and 12V compressor in one of the saddle boxes so I'm good for most flats. I came to the conclusion that hauling around that extra weight all the time wasn't worth the rare event that I might actually use the spare. I've only had one flat so far and I got that one plugged before all the air leaked out. If something really bad happens to a wheel I figure I'll have it towed anyway.
Normally I wouldn't argue with wisdom shared by 91 year old guyget a intake, i gained a coupple of miles on mine when i put it in with a B&B exaust and i have 26s
'Zactly. Anyone buying a CAI to increase their mileage (or HP/torque for that matter) is going to be sorely disappointed. Even provided one could keep their foot out of it, which would prove difficult in light of the increased bitchin' sound, a $300 +/- CAI is gonna take a long azz time to pay off MPG wise. But if it helps you slide one past the bride, good on ya, I'm not that fortunate because mine knows better!Normally I wouldn't argue with wisdom shared by 91 year old guybut I think your results are not typical of the average end user's experience with CAIs (my own included). I've never been able to appreciate any real gain in MPG after adding a CAI. With the high cost of the average CAI you'd have to drive a vehicle for 15 years to see a CAI pay for itself.
They do make the engine sound :cool2: though.![]()
I brought that up in another thread I started and several gentlemen pointed out what should have been obvious (at least as far as comparing 18s to 22s is concerned); they're effectively the same diameter and the speedo would only be off around 1MPH.I have a feeling the 26" rims and tires are a bigger overall diameter. If that is the case you are traveling further than you would with the stockers. So the gas mileage readings are artificially low. Also your speedo is reading slower because of the reduced wheel speed. You need to get a GPS to see your real speed and calculate from there. Then the best thing to do is have the speedo recalibrated.
Hi everyone I'm new to this Forum and just want to give my 2 cents on this CAI (Cold Air Intake) issue. I've been modding cars for the past 14 yrs ranging from Japanese to European to American Muscle. My last car was the BMW 550i and I always believed in CAI until my car went on the dyno and actually saw the results. My 550i actually lost 13 hps and 9 lbs of torque with the AFE CAI. Eloy the owner of RPI told me that the CAI actually sucks in more hot air then cold air and thats why it tends to lose HP and Torque unless you live in a cold part of the country. If you think about it the CAI has no insulation to keep out the hot air so your cars intake would suck in all that hot air your engines producing. After I saw the results I still didn't believe that it would make my car lose all that HP so I told him to put back my stock air box and we ran it on the dyno again and the car gained 13HP and 9 lbs of torque. And this is with out letting the ECU adapt to the stock intake so if I drove the car for about 300 miles the car would gain alittle more HP back. As for MPG, I didn't see any gain from installing the CAI. So from now on I'm sticking with the stock airbox. IMHO stick with your stock airboxNormally I wouldn't argue with wisdom shared by 91 year old guybut I think your results are not typical of the average end user's experience with CAIs (my own included). I've never been able to appreciate any real gain in MPG after adding a CAI. With the high cost of the average CAI you'd have to drive a vehicle for 15 years to see a CAI pay for itself.
And now the CTS. I brought my lade in for warranty service this week and they gave me an 09 CTS loaner. I was looking it over, checked in the trunk. Look, no spare tire. What's this gizmo latched down in the middle? It was a 12V plug in compressor with an integral can of tire patch sealant. You pump in the sealant, then pump up the tire. No jack. The owner's manual showed the jack and spare, no mention of the new system.That's a good suggestion. The Dodge/Chrysler/Jeep SRTs come with either run-flats or spare tire repair kits and no spare tires to save weight...for performance, but it works for gas mileage too.
