I'm partway through removing the steering wheel.
I have the four torx on the back backed out enough to remove the airbag (T30 if anyone is researching this later), but there's an annoying little blue clip stopping me from pulling the molex:
Is there any practical way to pull it other than buying yet another pair of needle nose pliers with narrower arms? I'm not managing to get my regular ones on to it . . .
I have the bolt off the steering wheel (21mm, iirc):
If I'm reading the various online instructions correctly, I now need a puller with hooks?
But what to the hooks attach to? This plate? The steering wheel casing is too soft to be pulled on without damage?
Is this the same puller as a pulley puller?
I expect some steering column to get exposed by doing this, but am not sure what it will be. Will there be something that lets me release the cylinder, or . . .
And it's a fine time to ask, but will the cylinder from a '95 Eldorado fit?
