1 - 20 of 28 Posts
The mufflers(original) on my Eldo weren't looking too good. I used denatured alcohol and a fine scotch-brite pad to clean them. Then, I sprayed them with a high-temp-semi gloss black. If you want them to look like stainless, there is a high-temp stainless pigmented paint, that has fine stainless steel particles, in it. I have used the stainless paint on my Z-28 exhaust system. It still looks new(1973 model). AS for the tips, I "borrowed" a fine pot cleaning pad from the kitchen(didn't want to scratch the finish). and used it with the alky to clean the tips. I put on some polish(NU-Finish), on the cleaned tips, they look new. The tips are welded on, so if yours won't clean up, try E-Bay for some new ones. Good luck...
2005 CTS-V, 1994 Infiniti Q45
see what you can wipe off first with a towel and some window cleaner. Then start scrubbing. You can get some stainless polish to shine them up once you have it cleaned up. You could probably go to an automotive store and the stuff you use to clean wheels would work good.
I use "00" steel wool on that kind of stuff. If you spray window cleaner on and hit it with the steel wool it works great. We also have this stuff at the shop called " Blue Away" That is very effective at removing heat related discoloration from chrome and stainless. The wool will also take off minor rust and stuff if it's not too deep!
Chuck, I didn't disconnect the mufflers. I just cleaned what I could see. But, hey, That's an idea. Take the suckers off, and while you're at it, you could clean up the underside of the floor pan(trunk pan?) as well. Now that would be a thorough clean job. I guess I like the Alky to clean stuff cause it reminds me of dragsters and one of my "other" fun time money pits....Nitro powered on-road/off road RC cars. WAAaaaaaaaaa/shiftWAAAaaaaaaaaa---42,000 RPM later, you're there... I know, off topic...I'm done
Never heard that one, but makes sense, if it can cut through carb stuff it should be able to get through carbon.
Oh! Yeah....I forgot to mention that! I use Carb cleaner or Brake cleaner all the time....Sorry about that Chief!
Gumout Carb. cleaner or Berrymans Chemtool spray or BrakeKleen or any number of other brands available at your local auto parts store in the cleaning section.
Carb cleaner is far stronger than Brake cleaner for getting carbon deposits off. You can buy it in any parts store. You can also use throttle body cleaner too. If you use brake cleaner, it will leave less residue than carb cleaner and dries very quickly, but just doesn't cut the crud as well.
Chuck, if you have "carbon" on the outside of your 1 year old mufflers, they might be shot. I can see where "carbon" looking gunk would be on the inside of your tips. If it's on the outside of the tips, does it burn a lot of oil, smoke like crazy. Where's all the "carbon" coming from?
That's what I thought!!!!! I was trying to understand how carb cleaner would come into play as per your question. BTW nice looking ride! I got a spoiler on mine too, but it has a LED light strip in it. I got it from Roman Chariot in Cleveland.
1 - 20 of 28 Posts
