UPDATE - GUIDE: How to Carb Swap your EFI 76 to 79 Cadillac with a 350 olds.
DISCLAIMER: Do at your own risk, I’m not a pro like the old dudes on this forum.
TORQUE SPECS -
All torque specs can be found by googling “350 Olds Torque Specs.”
ECU -
First, disconnect the ECU from the car. The ECU should be under the drivers side dash and for the 79 Eldorado it should be under the glove box on the passenger side.
EFI SYSTEM -
Once the ECU is disconnected you can begin to take apart the EFI system. Disconnect all the wires going to the injectors and sensors. The fuel rails have stands that hold them, once they’re removed the rails should come right off.
IMPORTANT - Make sure to release the pressure from the fuel rails so you don’t spray yourself in the face with gasoline.
There should be a male-female connector that holds the fuel rail to the fuel lines. Disconnect it, but leave the fuel line alone.
INTAKE MANIFOLD -
The intake manifold on the EFI Cadillacs have holes in them for the injectors. They can be plugged with pipe plugs and a 2BBL Carb can be installed on it. You can forge or buy EGR block off plates. Don't leave them open otherwise you'll have a massive vacuum leak.
If you want a 4BBL Carb you need a new intake manifold. This is where you either get lucky or it gets expensive. If you’re lucky, you can head over to a junkyard and find a car with a Carbed 350 olds.
VEHICLES WITH 350 OLDS -
1968-1977 Oldsmobile Cutlass
1968–1977 Oldsmobile Vista Cruiser
1973-1977 Oldsmobile 4-4-2
1968-1980 Oldsmobile Delta 88
1977-1980 Oldsmobile 98
1979-1981 Oldsmobile Toronado
1973-1979 Oldsmobile Omega
If you can’t find a 350 Olds non-efi intake, then you can purchase a Edlebrock Performer. They go for about 400-500, but if you’re lucky you can get them used for much cheaper.
The Valley Gasket for the Intake manifold will need to be cleaned and RTV will need to be put around the Coolant holes [?] to ensure that coolant doesn't leak into the oil.
INTAKE REMOVAL AND INSTALLATION -
IMPORTANT - Drain Your Coolant
REMOVAL -
This part will be the most difficult. There are a few things that need to be removed. First the coolant spout on the front of the intake manifold, then the coolant line on the back-left of the intake (passenger side), then you need to remove the throttle body along with all the vacuum hoses and air cleaner.
Once everything is removed, there are 6 bolts on each side of the intake manifold that need to be removed. They should be a 14mm or 9/16 socket. Once they're all removed you should be able to lift the intake manifold out. If you are having a tough time removing the intake, you can remove the distributor to give yourself more room.
INSTALLATION -
There are 2 gaskets that are on the far end and near the end of the engine block. DON'T Touch them. If they happen to break or move, you need to re-RTV them to hold them in place or replace them if they're broken.
Once you RTV the Intake Manifold Gasket, place it on the cylinder heads and allow it to dry for an hour. Put the Intake Manifold on the gasket after an hour, place the bolts back in place and hand tighten them. Wait another hour to torque the Intake Manifold Down.
DISTRIBUTOR -
The same distributor can be used but can be replaced with one from a carburated 350 Olds for better wire organization. I personally bought one for $150 for a '75 Cutlass.
The Distributor has 2 plugs, one with 3 connectors (closest to the distributor) and one positive wire that goes in the right slot of the 2 prong female connector.
FUEL PUMP -
This is by far the most tedious part. You need to jack up the rear end of the car. In front of the rear-drivers side tire, by the frame, there should be an inline fuel pump and a fuel filter. Make sure you have something to catch gasoline, then disconnect the hose running from the tank to the inline fuel pump. Let the fuel in the lines drain. Unscrew and unbolt the fuel pump, then disconnect it from the line holding it to the fuel filter. Unplug the wires from the pump.
IMPORTANT - The Intank Fuel Pump is suitable for the operation of the carburetor, there's no need to replace it unless it's faulty.
You need to install a fuel line from the metal tank fuel line to the fuel filter. I recommend using a 1/2 inch fuel hose. Clamp them down and you're done.
FUEL LINES -
The Metal fuel line that is left has a male connector on it. You can buy a male connector for cheap, then run a hose off of it.
Once you get the hose on it, you need to run a filter, then regulator, then hose to the carb.
You're entire fuel system should look like this:
Fuel Pump --> Line --> Fuel Filter --> Line --> Fuel Filter --> Line --> Regulator --> Line --> Carb
WIRING -
The Fuel Pump can be wired to any 12 Volt keyed power. To check for keyed power, take a multimeter and check a wire. If the wire is hot only when the key is on, then you're good to connect the pump there. I recommend connecting a kill switch to the fuel pump just in case. I use it if I want to have the car on, but not the fuel pump. You can get around this issue by having a mechanical fuel pump (on older 350 olds).
IMPORTANT -
On the 79 Eldorado, the Fuel Pump Power wire is on the Red connector from the ECU. It is the Thick Blue Wire.
On Earlier vehicles, I think it's the Green Wire, but I'm not completely sure. [Need Reference]
TORQUE SPECS -
ECU -
EFI SYSTEM -
INTAKE MANIFOLD -
REMOVAL -
INSTALLATION -
DISTRIBUTOR -
FUEL PUMP -
FUEL LINES -
WIRING -
IMPORTANT -
