1 - 8 of 8 Posts
2008 CTS Base
I understand any leak isnt a good thing. While changing the oil yesterday there was a pan directly behind the oil plug case. It had the smallest drip coming from where it seems to be the gasket seal and the pan. It seems like a clear liquid and not red. I thought it was the tranny fluid. I circled it in the pic below. It’s not even a big enough of a leak that would fall on the ground. The plastic pan that covers it has the smallest wet spot. Is this an ASAP fix or can it wait a little bit?
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
Well you sure didn't get your moneys worth from all those photography classes you took.
I would just clean it off and check it in a few days. If it gets wet, review your old photography books and take another picture that will show what we are looking at.
· Super Moderator
LOL, Flash!
MB, I have to agree, that is a bad pic.
Is it possible that it was just condensate water from above?
'12 CTS Performance Sports Wagon AWD
I think I have a leaky front diff but haven't looked into how much of a PITA it is to pull and replace the seals.
Rodney
Rodney
The Chilton flat rate labor book reads as follows;
R. side output shaft seal 1.5 hours
L. side output shaft seal 8 hours. Because you must remove the carrier differential to replace this seal.
Entire differential remove and replace 7 hours.
Below is from the repair manual. a lot of work. with special tools. The pictures did not copy over.
Output Shaft Seal Replacement - Left Side
Special Tools
GE-8092 Driver Handle
J 25070 Heat Gun
J 45017 Seal Installer
J 45019 Flange and Pinion Cage Remover
J 46265 Stub Shaft Seal Installer
Removal Procedure
Remove the carrier from the vehicle. Refer to Differential Carrier Assembly Replacement.
Click to Enlarge
Remove the bolts from the pinion bearing housing.
Click to Enlarge
Install the J 45019 flange and pinion cage remover and slide hammer.
Click to Enlarge
Using the J 25070 heat gun , apply heat around the pinion housing to ease removal.
Remove the J 45019 flange and pinion cage remover from the flange.
Click to Enlarge
Remove the pinion assembly, O-ring, and the shims from the from differential carrier.
Click to Enlarge
Remove the carrier side cover bolts.
Using the appropriate tool in the pry tabs, remove the carrier side cover.
Remove the O-ring from the side cover.
Click to Enlarge
Remove the differential assembly from the carrier.
Click to Enlarge
Remove the right output shaft seal from the cover.
Click to Enlarge
Using a suitable tool, remove the left output shaft oil seal from the carrier.
Installation Procedure
Click to Enlarge
Using the J 46265 stub shaft seal installer  (2) and GE-8092 driver handle  (1), install the left output shaft seal.
Click to Enlarge
Install the selected shims and the NEW O-ring on the pinion housing.
NOTE
Note
Inspect the bearing housing for nicks and burrs. Remove if necessary.
Apply a light coat of gear lube to the bearing housing to ease installation.
Click to Enlarge
NOTE
Note
Inspect the carrier pinion housing bore for nicks or burrs. Remove if necessary.
Apply a light coat of gear lube into the pinion housing bore of the carrier.
Using the J 25070 heat gun , apply heat to the differential carrier.
Click to Enlarge
Using the two long bolts from J 45019 flange and pinion cage remover as guides, align the housing bolt holes to the carrier bolt holes.
Hand tighten the guide bolts.
Applying even pressure, push the housing evenly into the differential housing.
Remove the long bolts.
Click to Enlarge
CAUTION
Caution
Refer to Fastener Caution.
Install the pinion housing bolts and tighten to 29 N·m (21 lb ft).
Click to Enlarge
Install the differential assembly into the differential carrier.
Click to Enlarge
Lightly lube the outside diameter of the oil seal with axle lube.
Using the J 45017 seal installer , install the right output shaft oil seal (21).
Click to Enlarge
Install a NEW carrier cover O-ring into the groove.
Apply a light coat of gear lube to the O-ring area.
Align the bolt holes and push cover onto the differential carrier evenly.
Start the cover bolts in the holes by hand.
Click to Enlarge
Install the side cover mounting bolts (1) and tighten to 29 N·m (21 lb ft) in a criss-cross pattern.
Install the drain plug. Refer to Axle Lubricant Change (w/o Differential Cooler) | Axle Lubricant Change (w/Differential Cooler 1st Design) | Axle Lubricant Change (w/Differential Cooler 2nd Design).
Install the carrier into the vehicle. Refer to Differential Carrier Assembly Replacement.
Fill the differential with fluid. Refer to Front Axle Lubricant Replacement.
Hmm... I could do that... lol
I probably have the specialty tools at work but my guess is if I get the diff out of my car that I would be better off taking it to someone and let them do the seal replacements.
But then again I wonder how much that sucker weighs and how much of a pain to do it laying on my back with it on jack stands. Luckily the passenger side of my car is where it seems to be leaking so hopefully that would be the easy repair. (First noticed it on the engine around the alternator when I swapped that but not loosing oil... Then noticed a bunch of it on the diff when I changed the fluid...)
Rodney
1 - 8 of 8 Posts
