1 - 20 of 27 Posts
06 STS-V & 06 STS 4 (sold 2016)
I'm wondering how often your GPS loses lock in your STS. Mine seems to lose it (GPS with the line through it on the Nav screen) every once in a while.
It does in the garage, of course, but that makes sense. But sometimes it loses lock when I have a wide open view to the sky. It's not that often, but it might last for a few minutes when it does happen.
I'm wondering if I have an intermittent problem or if this is just normal for the Nav system. I don't have anything on the dash at all. I know the GPS antenna is there. It's to the right of the light sensor.
Thanks.
Northern Colorado. And I've had it happen on the open road, no trees, nothing. Not too often, but just random, nothing I could put my finger on.
2006 STS V8 RWD 1SF
If it happens for a few seconds once and a while (with a clear view of the sky in at least 2 directions), it's normal as long as it comes right back. If it goes out and stays out, you'll want to consider the effects of window tinting you may have added, or perhaps even something hanging from your rear view mirror. My GPS stays locked on through tree lined roads normally and rarely looses signal. There are other threads that talk about GPS/radio interference caused by window tinting. From the posts I've read, I'd bet that's the most common problem.
Good luck !
~ Doug
15 SRX, 11 CTS Coupe, 11 STS, 06 STS, 06 CTS
Occational loss of GPS signal is normal. My job involves the use of GPS and GIS (Geographic Information System), so I have had many classroom sessions covering its use and implementation. There are multiple factors involved and the signal can be affected by many factors. I also loose my XM signal in certain areas for no obvious reason.
I think the real problem here is unmet expectations. As with any system, automotive or otherwise, it is designed to function in a certain way but people get the idea that it will do more than it was designed to do. ACC is another example. I certainly wouldn't rely on it to bring my car to a complete stop and keep me from hitting another car in the rear. Most of the complaints that I've read on this forum about the Nav system come from people expecting too much out of it. Most of the add on units that I've seen have such small screens that they are practically useless visually.
I also have had people comment to me on the lack of updated information in the system. Comments like "The street I live on is not on my Nav screen." They don't understand how the systems were developed and where the data comes from. Most systems started by using the U.S. census bureau's map data (call TIGER) as their base. We are constantly sending the bureau new data, trying to help them update their system. And then there is the whole issue of the POI's. Data for this comes from other sources. The bottom line is, don't have unrealistic expectations and you won't be disappointed.
14 CTS Vsport Black Tricoat/black, 16 Escalade Premium Lux Gray on Kona.
Well a realistic expectation is the ability to quickly and easily enter destination routes into the system, whether on the go or at a stop.
Any Garmin or other generic GPS can do this, and at a much faster rate. I can input a destination with 4 waypoints at a stoplight with a C330 (OLD unit). You can't even enter one in the STS' navigation. It is by far the worst implementation of an in car navigation. Disabling any modification except "Cancel Guidance" while driving is also ridiculous. What if you want your passenger to enter a destination? Bringing the car to a complete stop just to do that is a huge inconvenience not suffered on much cheaper GPS units.
Thanks guys. I don't have any aftermarket tint (on the car at all) or anything hanging from the mirror or anythng like that.
It's not me having my expectations too high; if it's normal, it's fine. I only want to make sure it's normal and not an intermittent GPS receiver or antenna, because if it is, I want to get it fixed before the warranty is up.
I have had it lose lock for a few seconds, but also (more rarely) a few minutes. One time in Wyoming, it lost it for about 9-10 minutes, with wide open sky on the highway. That's the longest time and I thoought that time was weird. That's what made me start paying attention to it.
Banned
05 STS4 V8 1SG with ACC
Well , I'm with mapmaker on this one.After learning and understanding my nav system I think it is pretty easy to use and just because I have to stop to feed it information doesn't make the system useless. Windot( If you feel that way buy yourself a lockpick).
You s hould not have to pay $200+ to hack a $2000+ option on a car. It should be made easy to use so that ANYONE can sit in the car and use the navigation system effectively. Garmin got it right. I can give a garmin to a 10 year old and have them input an address. Guarantee you even with the manual, a 10 year old could not operate the NAV in an STS. Cars are not meant to be complicated, they're meant to be a convenience (especially at a $60,000 price point). There is absolutely no reason the NAV needs to be as complicated as it is, considering it's price point.
05 STS
I agree with the Garmin comments. Garmin is so much easier to use and much better AND cheaper!!! Driving down the road I need a gas station or restaurant. Hit that catagory and Garmin says near here route or destination. Then it lists every resturant in an extended radius. Pick one and the phone number comes up. When we travel thats how we make hotel reservations. We determine where we may be at the end of the day and call around the area.
I have no problem with it not working while driving. Drivers have enough distractions.
Plus with a garmin I can get it updated by pluggin it into my PC.
none
I've seen a nuber of cars come through our body shop after a crash while the driver was fooling with the radio, let alone entering addresses in a nav. Just because YOU SAY you would let the passenger do it doesn't mean you won't distract yourself by fooling with the nav while driving...if you wanna do that, ...
Cadillac Owners Troll
2019 CT6 Sport 3.0TT,2015 Luxury ATS , 2016 ELR, and Volt
From what I read in the car mags, Honda seems to do the best overall with their nav systems as far as ease of use and functionality.
2006 STS V8 RWD 1SF
DUDE !?!?! Would you really trade your STS for a freakin' Honda? I know I wouldn't. The NAV system is complicated - agreed. Big deal, right? There are SO much more to these cars than the stupid nav that we may use 5% of the time. If you do go with the Honda, let me recommend the BIG spoiler, fart pipe and Type R badge options so you have a chance for a cameo in the next Fast and Furious box office flop.
Read the post Dude-I said they consistantly do a better job with Nav. Why does a 55K car have a decidedly worse Nav system than a 15K Honda. I don't want a Honda--I want a decent Nav system in an STS!
Premium Member
Take along a friend that knows the way.
That's probably the solution. I do like the looks of the IP with the Nav, and the other features that are bundled with it, but the lack of logic of the Nav function is just amazing not only for such an expensive car, but for a vehicle this new.
And this negates the fact that a $100 garmin is easier to use, easier to contol, and easier/cheaper to update than a $2000 option on a luxury car? What luxury is there then? It's about as useful as the voice control on the car.
2006 STS 1SG & 2007 STS 1SE
With some practice (and turning down the fan) the VR does what I need. I do believe the 'Windows Up' is rather useless over road noise. :) If you find the Nav too hard to use, use what you like.
The Nav upgrade and newer Nav disk versions do improve the system quite a lot.
Just like the N*, by the time technology is retired, it's finally all figured out!
Discussion Starter #20
Sorry, dumb question; what's the NAV upgrade? Is that where you load new firmware from a disk? I know what the new maps are and have that.
If that is true, where do you get the firmware update?
Probably been answered somewhere, sorry.
1 - 20 of 27 Posts
