1 - 20 of 32 Posts
V2
For those of you that have been asking the question it seems to be an estimated 550 with the stock internal components.
I was doing around 650 and mine started slipping today. Got an error code that a solenoid was stuck so prolly got some debris in it. Anyone doing 600+ your on borrowed time.
Circle-D (http://www.circledtrans.com/) is doing good things with the tranny. They have a 600 crank hp currently and a 800 crank hp in development.
I should have a built tranny hopefully this week. I will post my findings and results when I am done.
2009 CTS-V , 2010 SRX 2.8T
I'm honestly suprised that with some of the mods you auto owners have the first thing you don't invest in is in an additional transmission cooler like a nice setrab. It's the heat that kills the slushboxes
09 V B-B
Good fluid should help too, right?
^ fluid will help a little although not as much as the temperature of the fluid. Under the intake if you pull out that brake duct and put in a good transmission cooler with a bracket it would help alot in keeping the transmission togethor for alot longer.
2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
v2
CadV,
If you dont mind me asking - is Circle D building out your trans or do they have cores available so you can just exchange once they are complete?
Thx,
Chris
2010 CTS-V
With the new 6 speed autos from gm, the ability to handle more power is in who tunes it. The 6L90 in the CTSV is very similar to the 6L80 in the vettes. I had an A6 in my 08 vette making 700rwhp and it lived and I never took it easy on the car, it was driven hard. I would think 650rwhp on a stock tranny would live as long as the tune was right. Tuning the new autos is tricky.
2009 CTS-V
In talking to Jesse this weekend he had noted that the 6L90 is markedly stronger that the 6L80 used in say the Camaro.
However, running 650 rwhp in a 4200-4300 pound Caddy is alot easier on a trans than running it in a car that is nearly 1000 pounds lighter. Add regular use of sticky tires and high trans temps (I'll be getting an aftermarket trans cooler ASAP) and the longevity/durability becomes even more variable.
V2
Discussion Starter #13
CadV,
Thx,
Chris
GM will do the core swaps though. I am sending a new tranny straight from GM and then I will give them the old one after the built one is installed. You get a month to give them the old one.
V2
Discussion Starter #14
I am requesting a tune from them so I am perfectly compliant. They want me to use their tq converter as well so I am going to do it.
V2
Discussion Starter #15
That takes the cake on stupid comments. If he really did say that he is clueless.
V2
Discussion Starter #16
It comes with one stock.
2009 CTS-V
:tisk:
I transposed my thoughts and meant to say the opposite.....obviously.
Jesse only commented on the 6L90 vs. 6L80. I was commenting on the weight differences being a factor and botched the construction (and hence the meaning) of my reply, as you not so graciously pointed out.
cts-v
A couple of weeks ago I thought I needed a tranny. I already had an appointment with Jeremy Formato to tune my car. Then Jeremy tunes it and now the car feels like he put a race built tranny in it. The trans shifts perfect now. So I would have to agree that alot of it has to do with the tune. My car is making between 645 and 670 depending on the dyno.
09 V B-B
Just quickened up shifting or what?
1 - 20 of 32 Posts
