1 - 9 of 9 Posts
EXT 2002, EXT 2006,
Sorry if I have a bad English.... :rolleyes:
Im restoring a 1974 ford galaxie 500 that has the 5,8 l , 351 windsor engine
but I dont know how many hp it have, any idea? :confused: Also if I purchase a reconstructed engine how I know how many hp have if the seller doesnt know of what car is it ? Im thinking about a 390 ci who has like 365 hp
http://www.is-it-a-lemon.com/used-car-history/ford-galaxie-500.htm
1996 Eldorado Sport Coupe, 2009 Black Navigator
Trust me I don't doubt that their are plenty of people here that know the answer to your question but if they don't answer you might have better luck at a Ford.com type of forum. Not that you aren't welcomed.
Banned
1976 Eldorado project
The power of the engine depends solely on how you build it. And if you purchase a reconstructed engine, dyno it and see what kind of power it makes.
Hello Terrible One, everyone doesn't have access to a dyno so if its a simple question I'm sure at least someone has the answer to this question other than the ford guys(no offense intended).
1989 Sedan DeVille is now just a fond memory ....
About 168 with the 2 barrel carb. Now you have many options with this engine. You can purchase a rebuilt short block which is the engine block, crank, pistons, etc. with no heads. Or, you can purchase a long block which includes the heads, cam lifters, basically all of the internal running parts.
You will probably have 9:1 compression at best with either of those options which is good for todays gas. The cam will be stock, you could opt to replace it with a better cam for more performance. Or you could keep things simple and mild by leaving the engine stock and getting a nice torquey 4 barrel intake manifold, carburetor, performance ignition, good headers and dual exhaust all the way back. The car would be a better performer and still be very reliable.
Just a few thoughts.
EXT 2002, EXT 2006,
I like your idea Kev..thanks.. :) do you know of some good web page or bussines that sells all the components that you mentioned at good prices, besides summit racing wich is a little expensive ?
I would start doing Google searches for the components by name, for example;
Carburetors:
Carter AFB (Very nice, dependable, nice performance)
Holley (Good performers but complicated and temperamental)
Edelbrock
Rochester
Intake Manifolds:
Holley
Edelbrock
Headers:
Hooker
Hedman
Etc.
You need to form a plan, find out what is available and choose the parts you want, then search for the best deals.
Good luck with it and have fun!
94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
Sometimes Summit is a little expensive, but other times the competition doesn't even come close. I've had good luck with Summit (love the free hat), Jegs, and Scoggin Dickey.
1 - 9 of 9 Posts
