1 - 11 of 11 Posts
2000 Deville base 2019 Corvette Gran Sport
2019 Corvette Grand Sport, 2000 Deville Base (White Diamond)
On other forums if you want to delete your post you just go to edit and there is usually a delete button, I don't see that here unless I am missing something, so how do you delete a post?
2003 Deville Base
I'm not able to see the posts the way that you do. However, I'm not sure a user can delete a post. You can, however, edit to remove content but you must leave four characters (any 4, even periods). If there is a particular post/thread you started, pm me and I'll delete it.
The site does not normally delete posted info except under extenuating circumstances. That takes an Admin decision.
IIRC a member loses their own post edit feature after the post has been up for >12 hours.
Erroneous info can be corrected by posting in the same thread.
2003 Deville Base
RON93, I stand corrected. Sub has been a moderator way longer than I have.
Ron93, If you wish to materially alter or delete your posts and threads a day or so after posting, please PM me.
Wow sometimes you make a post and five minutes later you realize you did not want to say that and take the whole thing away not edit it. On Corvette Forum we just click a delete button and all is well, I thought that's the way it worked in all forums.
Any member should be able to edit a post/thread within 5 or 10 minutes of posting. I don't believe CF is set up to allow total thread deletion.
Your example - screen shot - shows a quote and its editor tabs - the post page does not contain the (red) "delete" tab.
Which forum, thread ? If you can't get into your post I'll remove it.
See if you can still edit your post, if so, simply delete the text.
1 - 11 of 11 Posts
