The switch was pressed way to hard and now is way down inside the center console. I need instructions/help on how to disassemble without breaking anything before I dive into this, thank you.
08 STS 1SG HUD ACC F55 AWD, 08 STS 1SG Platinum HUD ACC F55 RWD
It is held on by clips. Open console glove box and start pulling upward. Best to use plastic trim removal tools. Also note that the front edges are UNDER the bottom edge of the radio stack surround. Safest method requires removal of the surround first to avoid the possibility of breaking some locator tabs on the underside of the console trim. Radio stack also uses the same type clips. You should start at the bottom outside edges and wedge out toward the rear of the car and work your way upward with the plastic removal tools. These parts are sort of expensive so be careful. Good luck. Welcome to the forum. Lots of good helpful folks here. Please list details of your car ( and yourself generally) under account details - account settings. Will make it easier for someone to help you next time.
